12-17-2006, 02:57 PM | #1 |
Pebble Pounder Join Date: Oct 2006 Location: Sault Ste. Marie, MI
| Dimensions
I was wondering if anyone had dimensions (length and width) of their tube chassis. i dont need much detail, just length and width. thanks. Carson Wyckoff Also-what size tube did you use. Thanks Again |
12-17-2006, 04:34 PM | #2 |
Pebble Pounder Join Date: Oct 2006 Location: under a rock
this would be for ,what kind of axles? but as far as tube most use 3/16" or 1/4" depending on size.
12-17-2006, 04:39 PM | #3 |
Rock Crawler Join Date: Sep 2006 Location: Esco.
My tuber chassis is 10" long by 4" at it's widest point. Hope that helps. I used 3/16" brakeline.
12-17-2006, 04:44 PM | #4 | |
RCC Addict Join Date: Aug 2005 Location: Naoma, WV
If you go through and look at all the TLT tubers you'll notice there are different ways to go about it. Some have tube all the way past the axles while arthers are barely large enough for tranny and link mounts. Widths vary as well. But as long as people are posting lengths, a pic would help with getting a feel for how it is built. | |
12-17-2006, 05:41 PM | #5 |
i would also like to see picts. i dont really in mind. i was eyeing this one when it was posted in the f/s section. but it went in 5 minuits http://www.rccrawler.com/forum/showthread.php?t=52724 anything would help. Thanks |
12-17-2006, 06:02 PM | #6 |
Pebble Pounder Join Date: Aug 2006 Location: Suffolk
Most tubers will fall into the 10-14 inch long range, and between 3-6 inches wide. Like previously stated though, it will vary alot depending on what you put on your rig, battery placement, shock positions and if you want it to resemble a 1:1 rig or not. I base most of mine on full size rigs, and try to keep the tires proportional with the body. So decide what hardware you're going to run, what tires and how much flex you need, then build a box to accomodate the trans and radio gear and hang your fenders and tail end off that. Works pretty well for me, just remember to plan it out long before you start cutting tube, or you'll be pissed off, broke and still won't have a tuber.
12-17-2006, 06:04 PM | #7 |
If you need to see pics, just search "tuber" and use the tires as a size reference point. There is a list of all the tires and sizes also if you search for it, I think it's even stickied on the tires section...
