12-17-2006, 07:49 PM | #1 |
Quarry Creeper Join Date: Nov 2006 Location: Rats nest Grafton ND
| Which shafts?
Ok I did a search in the tips thread and was directed to either Pede shafts or Emax shafts. I was in the nearest hobbytown today and they only had some Jato shafts. I am using a locked Pede trans and either a 55 or 65 motor. I ordered the 4628X yolks to go on the transmission. Wheel base will not be more then 12.5. |
12-17-2006, 07:52 PM | #2 |
Pede shafts work fine. I prefer the Max for there extra stoutness.
12-17-2006, 07:55 PM | #3 |
Don't know if you know, But if you go with maxx shafts the biggest spur you can use is 84t but with pede shafts you can use a 87t spur.
12-17-2006, 08:00 PM | #4 | |
Well since I like stout I will go with the max shafts then. Have to call them tomorrow and let them know as they are ordering some links for me anyway. | |
12-17-2006, 08:02 PM | #5 |
RCC Addict Join Date: Dec 2004 Location: HELL.....
the maxx shafts require a little dremel carressing, and you will also need to drill the pinion for the set pin on the axle also you will need these yokes for both tranny and axle http://www2.towerhobbies.com/cgi-bin...I=TRAC4927&P=K |
12-17-2006, 08:05 PM | #6 | |
12-17-2006, 08:30 PM | #7 |
Pebble Pounder Join Date: Dec 2004 Location: Acton
I use maxx ones myself. with a Stealth tranny and a 98 tooth spur from kimbrough
12-17-2006, 08:36 PM | #8 |
Gettin’ back on the horse Join Date: Feb 2006 Location: Hoonsville
yeah i use the max shafts too. im runnin 64pitch gears was using the pede tranny and just growned down one of the out puts for a little extra room. now im running a stealth tranny with those shafts no trimming down nessary.
12-17-2006, 08:37 PM | #9 |
oh i forgot a 120 tooth spur
12-18-2006, 04:36 AM | #10 | |
Rock Crawler Join Date: Jan 2004 Location: Round Rock, TX
Maxx shaft, 4927 yoke, 87t spur on a 'Pede tranny. | |
12-18-2006, 11:02 AM | #11 |
Rock Crawler Join Date: Jun 2006 Location: Santa Rosa
i second that i use the 87t on with my maxx shafts. It is very close, but they dont rub! |
