Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Tamiya TLT Crawlers
Thread: Dez's BMVII Shadow Project
Old 12-29-2006, 11:48 PM   #81
Looking good Dez. I have most of my parts. I am still waiting on just a few more.
hlpressley is offline   Reply With Quote
Old 12-30-2006, 12:16 AM   #82
Nice looking rig!
The Blacked out look is Killahz ;)
Xtant3150c is offline   Reply With Quote
Old 12-30-2006, 10:39 AM   #83
Looking good as always....I'd like to see both the Grunts go toe to toe...I'm sure it will be close.
Old 12-30-2006, 11:27 AM   #84
Nice looking rig, Dez! Very clean.
ILoveRCRockCrawlin is offline   Reply With Quote
Old 12-30-2006, 11:38 AM   #85
Originally Posted by dezfan
I plan to test them head to head.
I'll use the rig that I feel is more capable for our comps next season.
The Pimp Cane Grunt is going to be hard to beat, pretty much dialed for Capen!
Pimp Cane Grunt huh....... sounds nice
Old 12-30-2006, 12:08 PM   #86
Looking super sano and clean dez think you might be pushing the 70% body rule though
Unimoger is offline   Reply With Quote
Old 12-30-2006, 12:13 PM   #87
ΜΟΛΩΝ ΛΑΒΕ
dezfan's Avatar
Why is that? :?
All I removed were the fenders.
Same body w/ the fenders.
dezfan is offline   Reply With Quote
Old 12-30-2006, 10:07 PM   #88
ΜΟΛΩΝ ΛΑΒΕ
dezfan's Avatar
More pics of the rear axle w/ the wedge installed.
Also, few shot's of the body only, looks like 70% to me?
Opinions? Questions? Comments?
Old 12-31-2006, 02:12 PM   #89
How does mounting the body like that work? When one axle flexes, isn't it going to twist the body? Body looks fine to me, all thats missing is the fenders like you said.
Old 12-31-2006, 06:51 PM   #90
Thats the point,, mounted in the center like that it will allow the tortion to twist and the body also. If it was mounted with 4 points the tortion would be extremly limited.
I mounted mine with 2 points up front and 1 in the rear, left the rear fenders intact and they make contact with the mounting plate which helps limit the articulation.
I can control the flex pivot point by moving the tranny plate forward or back.
Devlin
hotwheels000 is offline   Reply With Quote
Old 01-02-2007, 09:22 PM   #91
So is the bug body legal with the fenders trimmed off?
Twist is offline   Reply With Quote
Old 01-02-2007, 09:26 PM   #92
1st post in this thread has the 2.2 Bug bodied rig that won Nationals this year:
National Comp Rigs.......
Unholy is offline   Reply With Quote
Old 01-03-2007, 07:45 AM   #93
Since we're slightly off-topic anyway, has the USRCCA sanctioning body figured out how they will figure out if a body meets the 70% rule? I would assume that the best method would be by weight. Since there are a lot of popular bodies out there, a base weight could be established for each body. Then, a competitor's body could be weighed and a percentage calculated. So, say the stock HPI body weighs 12oz (have no idea on actual weight), and a competitor's body weighs in at 7.5oz, then his body is illegal (70% of 12oz is 8.4oz). I would think that this method, while not exact, would be moreso than someone just looking at the body and saying, "Yup, looks like 70% to me."
Back on topic, I'm looking forward to seeing how your BMVII compares to mine, performance-wise. There are some things that I see between our rigs that are quite different. I'm curious whether those differences are negligible or significant.
bugman72 is offline   Reply With Quote
Old 01-03-2007, 10:25 AM   #94
The trick around that would be to cut a little extra off the body to get the clearence you want and then put 8 coats of paint to add some weight to it.
TxCruzr is offline   Reply With Quote
Old 01-03-2007, 10:33 AM   #95
Off topic: There will be minimum size requirements and the 70% is up to the judge in charge of tech inspections. Weight isn't going to cut it due to people can cheat the system too easily. 3" tall, 12.5 inches long and full width at the cab is the measurements if I recall correctly. The 70% is subjective, but I don't think it's that hard to agree on.
On Topic: Seeing the 2 BMs go up against each other with you 2 being skilled drivers will be good. Next comp will be cool to watch.
Old 01-03-2007, 11:46 AM   #96
ΜΟΛΩΝ ΛΑΒΕ
dezfan's Avatar
Looks like the torsion chassis are starting to take over at our comps.
2 BM+VII's, Eric's home brew torsion TLT, R2J Pimp cane, my Pimp cane.
Add that to Unholys Stick Clod and Travis's Stick TLT!
The TVP's are doomed!
Old 01-03-2007, 11:58 AM   #97
Thats what I like to hear BWAHAHAHAHAHAHAHA
syco133 is offline   Reply With Quote
Old 01-03-2007, 02:09 PM   #98
That's one of the reasons why I've been thinking about unloading my P4 chassis and going all torsion-style with my rigs. The P4 was a very capable rig...for a 4-link shocked crawler. Driving the BMVII and then driving the P4 is a night-and-day difference. The P4 seems a LOT overweight compared to the BMVII. Strangely, there really isn't that much difference in actual weight between the two. The P4 just seems more like driving an elephant and the BMVII seems like driving a billy goat!
Old 01-03-2007, 02:17 PM   #99
ΜΟΛΩΝ ΛΑΒΕ
dezfan's Avatar
Wish you guys would quit BSing in my thread!:-P
But I think I'll have the Shadow ready this weekend, wount have the BL set up in it, but it will still be on the rocks!
Old 01-03-2007, 02:17 PM   #100
...unloading my P4 chassis.
The P4 seems a LOT overweight...
The P4 just seems more like driving an elephant...
I'm thinking you wouldn't make a very good salesman... :-P
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
