01-06-2007, 01:21 PM | #41 | |
Gettin’ back on the horse Join Date: Feb 2006 Location: Hoonsville
01-10-2007, 07:36 PM | #42 |
Rock Crawler Join Date: Jan 2005 Location: Post Falls
I just rebuilt mine. It's working better than ever. I've tried alot of different set ups with this chassis, let me know if you need any help. Last edited by Reef; 01-10-2007 at 07:39 PM. |
01-10-2007, 07:58 PM | #43 |
Rock Crawler Join Date: Jun 2006 Location: huh?
I really like the paint on your rig and the wheels just make it look even more sick |
01-13-2007, 10:00 AM | #44 | |
RCC Addict Join Date: Aug 2006 Location: trying to find out what a TVuPer is.....
02-16-2007, 11:15 PM | #45 |
Rock Stacker Join Date: Feb 2007 Location: in the garage
How did you center (side to side) the R2 without the outputs (yoke) hitting the upper link at the chassis.I used a brushed motor and had to mount the tranny off to the left and forward to clear.
02-16-2007, 11:42 PM | #46 | |
RCC Addict Join Date: Mar 2006 Location: Bedias, Texas
We also will drill the holes for just about any kind of tranny you'd want when you order it including the R2. David Xtreme Rc Hobbies | |
02-17-2007, 08:50 AM | #47 | |
02-17-2007, 10:12 AM | #48 |
Pebble Pounder Join Date: Jan 2007 Location: Livonia
If you mount it in the center of the skid, the drive shaft hits the closest upper link at about 75% articulation to one side. Basically, you'll have to mount the R2 with one side hanging off (motor side) if you want as much articulation as you can possibly get. |
02-17-2007, 11:17 AM | #49 |
mine does not hit at all... it fully compresses the shocks both front and rear, keep in mind I am running 3.5" shocks in front and 4" in rear. |
02-17-2007, 11:24 AM | #50 |
Pebble Pounder Join Date: Aug 2006 Location: Albuquerque
I ended up chucking the stock skid/tranny mount and mounted the R2 between the frame rails as a structural member. Then I made a new skid that mounted to the bottom of the R2. Unfortunately the R2 is wider than the XRC chassis, so I also replaced the upper chassis braces with wider ones. Definitely not the easiest way, but I was able to drop the entire tranny/motor assembly down ~.5". This not only lowered the CG, but also lessened the driveline angles a bit. Now it clears everything quite well. |
02-17-2007, 12:25 PM | #51 |
Rock Stacker Join Date: Jan 2007 Location: some where
looks really nice
02-17-2007, 01:09 PM | #52 |
Pebble Pounder Join Date: Feb 2007 Location: Alaska
where did you get the rims and beadlocks at?
02-17-2007, 01:31 PM | #53 | |
if it was not setup for the R2 could you tell me if it had holes at all. I see that you requested to drill the holes yoursef on our website then wrote an email asking for R2 holes. If you have no holes we must have confused the website order and missed the email. If so I apologize. Sincerely, David | |
02-17-2007, 01:52 PM | #54 | |
02-17-2007, 01:56 PM | #55 |
The holes were drilled for the links but not the tranny.It would be hard for you to know where the tranny will be mounted because,it can be mounted in several different ways. Depending on the use of a shorter brushless motor,or the longer brushed motor.I'm not afraid to drill some holes myself.Everyone as a different setup.I hope mine turns out as good as the bronco. Last edited by srjeeper; 02-17-2007 at 02:06 PM. |
02-17-2007, 02:23 PM | #56 | |
02-18-2007, 12:37 PM | #57 |
Quarry Creeper Join Date: Aug 2006 Location: Palm Harbor
Where did you buy the Erikson beadlocks? Can't find anywhere.
02-18-2007, 01:23 PM | #58 | |
02-18-2007, 01:31 PM | #59 | |
02-18-2007, 04:33 PM | #60 | |
