Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Heritage Crawlers > Tamiya TLT Crawlers
Thread: My tlt build
Old 01-02-2007, 11:04 PM   #21
Originally Posted by pvtjrt01550
the axle C's are kick a** and that is a part that takes a pretty good beating if you don't mind some cutting and grinding go for them you can't beat the price and they really toughen up a weak spot on the axle.IMO Blackfoot axles are the cheapest way to get a little wider without completely screwing your steering and just a note about lrp AI runner esc's they have a 3 second reverse delay i love mine but it takes some getting used to...
axle c pic...
So should I go with wideners or axle c's first?
Brandon M is offline   Reply With Quote
Old 01-02-2007, 11:06 PM   #22
well the wideners are pretty much a must to mount 2.2 tires so I'd go with them..
pvtjrt01550 is offline   Reply With Quote
Old 01-02-2007, 11:08 PM   #23
What do you recomment I will do other then the blackfoot wideners
Old 01-02-2007, 11:16 PM   #24
the gmade wideners from the crawler store are nice I personally don't like barrel nuts (I tend to break them..lol)
www.thecrawlerstore.com
Old 01-02-2007, 11:26 PM   #25
Kool ima order those after I order my chassis
so it will be like this
chassis, gmade wideners, axle c's, alumn nuckles, Bearings, Alumn shocks
Old 01-02-2007, 11:31 PM   #26
that sounds about right but you might want to think about getting the bearings and the axle c's around the same time cause you'll have to have the axles apart ot mount the c's so that would be a good time to put the bearings in and button everything up
Old 01-02-2007, 11:37 PM   #27
Thats true but I dont mind taking things apart its kinda fun I think i am going to order the bearings with the knuckles since there from the same person
Old 01-03-2007, 08:57 AM   #28
good choice bro
i already have the bearings in they make a huge difference
and i also ordered the aluminum knuckles from Jp Custom Rc's
the fat rock axle c's from fatrock
I'm just watinng on the first two to come in together with the esc and tranny my axiom motor already is in
the stampede sliders are in just waiting on BBY for the steel yokes
and the most awsome thing was the RC4WD bead lock rims with the fat red ring these are great
keep up the good work looks like we will finish around the same time I'm still saving up for the body and paint job
chivas72 is offline   Reply With Quote
Old 01-03-2007, 09:43 AM   #29
Big Mike's Avatar
does it make a difference whether you triangulate it there or triangulate it inside the chassis??
It did for me - Triangulating inside the chassis did not seem to help at all - when I made new servo plates and triangulated at the axle it freed up much articulation. And eliminated the majority of the flex-steer.
and you also need to move your tie rod to the top (Gives more clearance)
Most definitely. Stack both of the tie rods on top of each other on top of the knuckle. Gives you a much better approach angle. And ditch the servo savers for solid horns. Servo savers just rob your servo torque, when you really need to turn the wheels in a tight spot, the servo saver will actuate instead. This is rock crawling, you're gonna have to expect to break things. Plastic geared low torque servos are not going to last you more than a week.
Big Mike is offline   Reply With Quote
Old 01-03-2007, 11:01 AM   #30
Originally Posted by chivas72
good choice bro
Maybe but I only have 40 to spend for a week of too after I order double js chassis today
Old 01-03-2007, 11:50 AM   #31
are these worth $27? seems like there are a lot of options, and these are on the edge with them all?
gopher is offline   Reply With Quote
Old 01-03-2007, 12:58 PM   #32
are they worth 27$ sure there stout and they work well but imo 7$ blackfoot axles work just as good and NO BARREL NUTS!!!
Old 01-03-2007, 05:37 PM   #33
Sent my money out today For my powdercoated black Vertical smile chassis with the 3 inch delrin skidplate. It will be shipped friday!
Old 01-03-2007, 08:54 PM   #34
I joined the Band!
Looks pretty good, but the body is waaayyy to small.
Knoc is offline   Reply With Quote
Old 01-03-2007, 09:16 PM   #35
Read my post! i put in the main post the body is on it for now, until I buy one.
Old 01-03-2007, 09:20 PM   #36
*IS THIS POST CONTRIBUTING TO ANYTHING HELPUL* nah....
Old 01-04-2007, 10:26 AM   #37
i am thinking about taking my rear stear out because i dont have a good rear stearing servo and because its going to suck as a full time rear stear thats not independant
Should i
Old 01-04-2007, 11:02 AM   #38
im building one too and im keeping my rear stearing because im gona use my rig for crawling only
nitromtcrawler is offline   Reply With Quote
Old 01-04-2007, 11:12 AM   #39
Default rear steer
Should i
i'm gonna go for the dig option you never know if you are gonna be competing and 2.2 clas has no rear steer plus i would never be able to afford rear steer on my 1:1 so there is my 2cents
Old 01-04-2007, 09:12 PM   #40
You make a good point I might not run it we wil see when I get it running
Edit this is awesome I got like 90 bucks and my dad Said that he is going to buy my body and paint for me once the truck is a rolling chassis
and double j is shipping my chassis tommorrow
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
