01-06-2007, 01:55 PM | #1 |
Quarry Creeper Join Date: Jan 2007 Location: Shingle Springs
| Non steering aluminum rear axle knuckle conversion?
Does anybody make anything like this? Since you can't have rear steer in the 2.2 class it seems like this would be a good product to have. A bolt on rear knuckle that attached like the Fat Rock Cs. No king pin. All one piece for more ground clearance and so you didn't have to use tie rods to keep your rear tires straight.
01-06-2007, 02:25 PM | #2 |
That's a great idea!!!
01-06-2007, 02:33 PM | #3 |
I wanna be Dave Join Date: Oct 2006 Location: Martinsburg WV
I'd personally rather see a change in the rules. But until then that is a good idea. They could still be affordable in a bolt-on format like the Fat Rock C's. What I have in mind would require welding, though. It would not be as easy to make as the C's, cause they would also have to be machined to carry a bearing. You'd also need to make longer inner axles. Last edited by Big Mike; 01-06-2007 at 02:36 PM. |
01-06-2007, 03:15 PM | #4 |
Rock Crawler Join Date: Jun 2006 Location: Oak Lawn, Illinois
I edited yours to one with more clearance |
01-06-2007, 03:25 PM | #5 |
Dirt Addict Join Date: Jan 2004 Location: Stumblin' thru the parking lot of an invisible 7-Eleven
Something like this? Jay |
01-06-2007, 03:36 PM | #6 |
Quarry Creeper Join Date: Mar 2006 Location: Australia
thats fantastic... did you make those yourself?
01-06-2007, 03:39 PM | #7 |
I wanna be Dave Join Date: Sep 2005 Location: R.I.P. Chip
That is SWEEEET! More info pleaze. |
01-06-2007, 05:36 PM | #8 |
Pebble Pounder Join Date: Apr 2006 Location: grand rapids
| I was thinking about this the other day while I was looking at the scaler forum. This is what I drew up. Not to scale or anything. I was thinking it could be made out of a piece of aluminum square stock. |
01-06-2007, 05:54 PM | #9 |
Pebble Pounder Join Date: Feb 2005 Location: San Diego
Dumpster I was thinking the same thing. Wouldn't be hard to make just a little time.
01-06-2007, 06:03 PM | #10 |
Rock Crawler Join Date: Dec 2005 Location: Borderland Tejas
Someone could just machine a small spacer that would fit over the shaft between the axle housing and the knuckle and that could keep it from turning. Would be a really cheap way to get rid of running a tie rod back there.
01-06-2007, 06:12 PM | #11 | |
Toyota Trail Truck | |
01-06-2007, 06:42 PM | #12 |
Quarry Creeper Join Date: May 2006 Location: Chandler
Somebody should produce these. I know I'd buy them.
01-06-2007, 07:37 PM | #13 |
Pebble Pounder Join Date: Aug 2006 Location: High Point
i like the ones eric llinked to, that way, you could remove them if you wanted rearsteering
01-06-2007, 08:23 PM | #14 | |
Brazed an inner axle to an outer with a piece of tubing to get rid of the dog bone joint. Jay | |
01-06-2007, 08:25 PM | #15 | |
Dude you should Get a vendor star and start producing those | |
01-06-2007, 10:45 PM | #16 |
Pebble Pounder Join Date: May 2006 Location: CANYON LAKE
nice i need a set |
01-07-2007, 01:34 AM | #17 | |
EDIT: How long are Tamiya Hornet rear inner axles? http://www2.towerhobbies.com/cgi-bin...?&I=LXLDZ3&P=M Tamiya Shaft Bag 58347...no dimensions given unfortunately. Who's got a couple to measuer? Last edited by Natedog; 01-07-2007 at 01:48 AM. | |
