01-29-2007, 11:06 PM | #41 | |
RCC Addict Join Date: Mar 2006 Location: Bedias, Texas
David Xtreme Rc Hobbies Last edited by insanerc; 01-29-2007 at 11:16 PM. | |
01-30-2007, 03:28 AM | #42 |
Pebble Pounder Join Date: Jan 2006 Location: Chattanooga
Although the truck is 3/4" lower now (this pic was before running it) with the tranny mounted slighly forward and the rear pinion angle raised this chassis provides nothing but slick delrin for the rocks.If the front wheels can bite it will drag the rear up 90% of the time. |
01-30-2007, 05:13 AM | #43 | |
Sincerely, David Xtreme Rc Hobbies | |
01-30-2007, 11:17 AM | #44 | |
Quarry Creeper Join Date: Nov 2006 Location: Lexington Park
01-30-2007, 02:52 PM | #45 | |
With the bent HC links I like to see them come off the chassis level with the chassis untill they reach the bend. When adjusting your shocks remember that articulation is very much over rated and you really only need about 45 degrees or so. Just look at all the torsion rigs and how well they perform to see this point driven home. Also keep in mind the you can lower your C.O.G. without actually shortening your shock throw. The way to do this would be softer springs, maybe a lighter shock fluid, and have some droop which is very desirable if your chassis is well balanced, and your link geometry is good. David Xtreme Rc Hobbies | |
01-30-2007, 04:59 PM | #46 |
Rock Crawler Join Date: Jun 2006 Location: Santa Rosa
can droop be explained as "riding in the suspension". It seems my tlt always is sitting on " top of the suspension", even though i losi soft springs and 25wt oil. My shocks are pretty soft, but they dont "ride in the suspension". Thanks, this has been a great guide to everyone, even those w/o xrc chassis |
01-30-2007, 05:30 PM | #47 | |
02-05-2007, 02:23 PM | #48 | |
Rock Stacker Join Date: Jan 2007 Location: Newburyport, MA
I'm new to crawling and am still reading/learning before I start my own build. I recently bought a used SW2 rig that's really helping me learn how to crawl and understand how all the parts go together (and I get to crawl while learning). It's also made me very anxious to build my own as well. After searching & reading build threads and hundreds (if not tousands) of tech posts on most of the well known chassis'...I think I've made my choice. An XRC is in my future. Do I understand this correctly...the XRC Roller kit will give me everything I need minus the electronics? That'll save me some time... | |
02-05-2007, 05:49 PM | #49 | |
02-05-2007, 09:19 PM | #50 |
cant wait to see the updates to the website
02-15-2007, 04:16 PM | #51 |
I'm adding to this thread and pulling it back to the front page because I have so many people that are new or fairly new to crawling, and are asking for setup info. Other than the above there are only a million things left that you can do to make your XRC more capable. Maybe some of you have seen some of the torsion rigs lately rolling their rear pinion angle upwards. This is something that you can do every bit as well with your 4 link setup as long as you keep your link geometry correct. I advise you to do so to keep the rear driveline out of the way on breakovers. The point is that on a 2.2 comp machine your going to have to lock out your rear steer anyway. Other than helping to move your pinion up out of the way you are also straightening out your driveline angle which eases stress on the components and makes for smoother crawling. I'm going to leave any illustration here that I drew up real quick so you may see the difference. David Xtreme Rc Hobbies |
02-15-2007, 07:29 PM | #52 |
As i understand the best way to make this axle angled upward it to move the upper links longer. I have a sw2 but i think i can just adjust the upper links so they push the axle upward. What are some problems that may be seen while doing this? You said to make sure the link geometry stays the same. Thanks i appreciate it alot.
02-15-2007, 09:39 PM | #53 | |
Here is a very good thread that you may want to read: Anti Squat and Suspension Tech David Last edited by insanerc; 02-16-2007 at 08:37 AM. | |
02-16-2007, 06:54 AM | #54 |
This settup works extremely well.Stock xrc chassis,xrc 5/16 links.R2j 110mm shocks limited with fuel line. Note no rear drive line exposed.Only slight tilt in rear end is needed. |
02-16-2007, 07:01 AM | #55 |
With a stealth and a lightweight brushless cog would be even better,but it's already better than a lot of trucks. |
02-16-2007, 09:10 AM | #56 |
thanks insane, i will defeinently read that thread. i am dieing to learn how to set up links the correct way. Blake that xrc looks good!! |
02-16-2007, 03:28 PM | #57 | |
02-16-2007, 03:41 PM | #58 |
I wanna be Dave Join Date: Apr 2005 Location: Eastern WA
Just thinking, if you took some HC links, eight of them, and turn the top ones upside down, it'd be lower COG.
02-17-2007, 02:15 PM | #59 | |
Newbie Join Date: Sep 2006 Location: bordentown, nj
03-06-2007, 09:10 PM | #60 |
any updates?
