![]() | #21 |
I want to thank ILRCRC for the help w/ the pics! ![]() |
![]() | #22 | |
RCC Addict Join Date: Dec 2004 Location: Central NY
| ![]() Quote:
![]() | #23 | |
| ![]() Quote:
![]() If anyone else has anything to add, please do. I want this guide to as complete as possible! ![]() | |
![]() | #24 |
RCC Addict Join Date: Jan 2007 Location: San Jose
Thanks Dez, for explaining the tranny's! Very helpful. For the pede tranny do you think the gear reduction is good, useful? It is the gd 600 at tower i think. How does that work and how is install? Thanks dude!
![]() | #25 | |
| ![]() Quote:
But I see lots of other use them w/o a gear reduction. Just use the correct size spur and pinion. | |
![]() | #26 |
Im Brandon ![]() Join Date: Feb 2005 Location: Colfax, CA
Not that its extremely applicable but it would be cool to have some of the other trannies crawlers use, and not just the comp rigs. The following: High Lift 3 speed Bruiser 3 speed E Maxx tranny I have even used a Jato tranny with the single speed conversion... Doubt anybody else would try it but it was super small, very very durable, and had the traxxas outputs on it already ![]() Great work Dez ![]() |
![]() | #27 |
Quarry Creeper Join Date: Jan 2006 Location: Redmond
Picture of XX CR Tranny ![]() ![]() And installed in stock TLT Chassis ![]() |
![]() | #28 |
Quarry Creeper Join Date: Jun 2005 Location: quarryville
i have a rustle ![]() ![]() |
![]() | #29 | |
| ![]() Quote:
![]() | #30 |
BTW, on the XX CR Tranny, the only good way I found to get the Maxx shafts on it was to hog out the cups on the traxxas shafts and install them over the XX Output shafts. It has been holding up very well, but mounting the tranny can be a pain, the mounting ears are kind weak, I ended up making a little Peice out of some brass that mounts to one of the motor mount screws as you can see in the pic.
![]() | #31 |
Thanks for the pic! ![]() |
![]() | #32 |
Thanks dez. Do you know what some good combo's would be for sput and pinon. For example, 84 spur and 13 tooth. Is that a good combo? Thanks.
![]() | #33 |
Quarry Creeper Join Date: Feb 2005 Location: Lake Tapps, Washington
just a note on the xx trans the gear case is not available new anymore. I B.. |
![]() | #34 |
This is true, the other downside to the XX is the tranny is so phsically short that when you put on the traxxas shafts like I did you end up running smaller spur gears, so while it's better than a TLT tranny, it is about the same ratio when all is said and done, I am running a 12T Pinion and 90T Spur, Standard 48P. But it still crawls pretty well with a 65T, almost too slow, I am taking the pinion up a little. |
![]() | #35 |
I wanna be Dave Join Date: May 2006 Location: Arlington, VA
what about the wheelie king trans, anybody try one of those yet in a none WK application?
![]() | #36 |
Main problem is, that the tranny isn't available by itself and not many WK owners have probably ripped apart their trucks to build a real rock crawler yet, someone was building one into a crawler on here, I think he used the stock tranny and it was working ok for him, so you might check out his thread. ![]() |
![]() | #37 |
I'll look into the WK tranny and see what I can find out. Thanks guys, keep the ideas coming. |
![]() | #38 |
i bought one from john rob but arnt sure yet to use it for a scale trail beater or not. let me know if you want some pics or dimensions or anything, more than glad to split the case and snap a few or throw a micrometer to it.
![]() | #39 | |
| ![]() Quote:
![]() | #40 | |
| ![]() Quote:
That would be nice, wouldn't mind seeing if they are metal gears, plastic or what, with the case split it starts to become more evident if there will be weak spots or not. Also, if you could get a rough idea of the ratio by seeing how many spur turns it takes to turn the outputs. I would assume it would be geared pretty short to get good wheelies, if so, it might be over 3:1, which would make it a awesome possibility in crawlers, as the Pede is only 2.72:1 | |
