02-09-2007, 04:04 PM | #41 | |
I wanna be Dave Join Date: Apr 2005 Location: Vegas
02-09-2007, 07:35 PM | #42 |
Rock Crawler Join Date: Jun 2006 Location: capon bridge
Thanks dez for the picts. Do you have any picts of the losi XXX Slipper clutch, spur gear assembly? Or any one else. |
02-09-2007, 08:05 PM | #43 |
RCC Addict Join Date: Apr 2006 Location: Brighton
Great tech article Just wondering if some mesurements might be useful to those that build a chassis, be it some of the big name vendors here, or the guy building something "revolutionary" in his dimly lit shop at home. |
02-09-2007, 08:28 PM | #44 |
Quarry Creeper Join Date: Jan 2006 Location: Redmond
Oh, just to let you know the XX Tranny shot I uploaded, the slipper and spur gear are not setup like stock, that is a custom peice on the shaft I put together.
02-09-2007, 08:36 PM | #45 |
If you ever have the tranny out, I would love a opened up side view of it like the others as well. |
02-09-2007, 08:43 PM | #46 |
If I ever end up getting a different chassis I will get you pics of the internals, but that is about the only reason it will ever come out. I am sure I will do something with it eventually, but not for another couple months.
02-09-2007, 09:08 PM | #47 |
Quarry Creeper Join Date: Nov 2006 Location: Lexington Park
great write up dez i have been thinking about upgrading to a r2 tranny from my current tranny a stampede. the only thing im a little unsure about is the BIG difference in the gear ratio's. going from a 2.61 to a 10:1 sounds like my comp rig would literally be "crawling". i like a little wheel speed ya know. will i be able to make up the difference with a bigger pinion? it looks a little small inside the case and i think i heard someone say their was a limit to how big a gear you could fit. any advise you can throw at me would be much appreciated |
02-11-2007, 05:57 PM | #48 |
You could always run a motor w/ less turns (35t for example) and add a few cells to the mix! |
02-13-2007, 12:48 PM | #49 |
Rock Crawler Join Date: Aug 2006 Location: On the trail
EXCELENT POST! very useful information.... whats the difference between the old pede (black one) and the new one(gray one)? wich is lighter the pede or the r2? thanks thanks |
02-14-2007, 04:51 PM | #50 | |
RCC Addict Join Date: Sep 2005 Location: ...Here & There
Or ideas on eliminating it, other than putting screws in it. (I'm searching now. Which is how I found this thread) I can't get the slipper figured out... | |
02-14-2007, 08:05 PM | #51 |
There are slipper eliminators available, the dirt oval guys use them often.
02-14-2007, 08:20 PM | #52 |
I wanna be Dave Join Date: Jun 2005 Location: On the G-Train!!!!!
Dez, you forgot about this. It's a GT2 tranny. It's smaller & lower than all previous stealth's, it also has an internal ratio of 4:1. Here's a pic of it with a spool I made from a NTC3 spool. You can see the new stepped idler gear. |
02-15-2007, 10:54 AM | #53 | |
RCC Addict Join Date: Sep 2005 Location: Behind the torch!
Gear Ratio (1st Gear) * 11.73:1 (total gear reduction) Gear Ratio (2nd Gear)* 8.75:1 (total gear reduction) But nothing about the single speed. Any help would be appreciated. Thanks. | |
02-15-2007, 10:58 AM | #54 | |
What about the spur/slipper/motor plate setup? Being a nitro tranny I'm assuming that you would have to fab your own motor plate? Last edited by dezfan; 04-10-2007 at 03:34 PM. | |
02-15-2007, 03:06 PM | #55 | |
02-15-2007, 05:21 PM | #56 |
OMG that has to really slow.
02-19-2007, 08:07 AM | #57 |
Quarry Creeper Join Date: Apr 2006 Location: BND
Thats a great write up thanks for the info. I was wondering about the electric Traxxas Hawk transmission. Are these any good for crawlers and has anybody used one. I got a couple Hawks just sitting on the shelf. |
02-19-2007, 08:31 AM | #58 | |
Rock Crawler Join Date: Oct 2005 Location: Clarkston, MI
02-19-2007, 08:59 AM | #59 |
I wanna be Dave Join Date: May 2006 Location: Arlington, VA
yeah, and v2 of the r2 is supposed to be able to handle up to a 17t pinion.
02-19-2007, 06:16 PM | #60 |
Rock Crawler Join Date: Mar 2006 Location: Auburn, WA
For you guys running a Losi tranny, I think these can be used in both double and triple X models, and can be used with minor mod to install Traxxas drive shafts http://www.horizonhobby.com/Products...rodID=LOSA3095 |
