05-20-2007, 08:18 AM | #121 |
Rock Crawler Join Date: Jul 2005 Location: Central Coast
Anyone know the ratios of the High-lift 3 speed? |
06-05-2007, 01:22 AM | #122 | |
I wanna be Dave Join Date: Jun 2005 Location: drillin Holes for the man
06-05-2007, 07:04 AM | #123 |
Quarry Creeper Join Date: Jan 2007 Location: Isanti, MN
| you use xx outdrives for both transmissions. a friend of mine has had them superglued to his diff gear for a year with no problems. just get a very abrasive sandpaper, make 2 disks that fit in the diff gear, scratch up the diff rings and then glue the grit side of the sandpaper to the diff rings, and the back to the diff gear. before this you should clean the grease off of your diff gear and other components.
07-24-2007, 08:01 AM | #124 |
Newbie Join Date: Jul 2007 Location: S
I have an extra Savage X 2speed tranny, not too sure if this can be use as well?
08-16-2007, 09:39 PM | #125 |
Rock Stacker Join Date: Oct 2006 Location: phoenix
| locking rustler tranny
can some post up some pics where to jb weld on tranny please
08-16-2007, 09:42 PM | #126 |
08-16-2007, 10:43 PM | #127 |
| tranny |
08-16-2007, 10:49 PM | #128 |
08-19-2007, 03:41 PM | #129 |
I wanna be Dave Join Date: Feb 2006 Location: Campbell, CA 4 hrs 2Rubicon !
help please thank you dezfan for making a great write up, but tryig to build my new super and getting confused on trannies What tranny is a strong tranny for a Super ? I bought a rc4wd 2speed tranny but I'm reading that they are weak ... should I return it? using a BM16 brushless 8.4 volt Don't Us Crawlers need a Sliper ? so things don't break What about the Twin force tranny ? Anybody modify a Emaxx tranny to be lower cog PS How do you trim down the shaft on a GD600 ? , not big enough to put in a lathe machie, do you press the shaft off the gear? Thanks guys Last edited by toy4crawlin; 08-19-2007 at 04:27 PM. |
08-20-2007, 12:33 PM | #130 |
Not sure as this guide was aimed at the 2.2 TLT crowd. Maybe a post in the Maxx section might get you some help. Good luck! |
08-20-2007, 01:43 PM | #131 | |
yea not sure on emaxx, it's So huge I may use a MIP with Brass gears and reduction units, see my build thread last page for details. | |
09-11-2007, 06:03 PM | #132 |
Quarry Creeper Join Date: Jan 2007 Location: US
Is there a difference between associated B2 and B3 trannies? The B2 is kinda skipped in the first post. It says... "The Gen 2 & 3 Stealth B3/T3 tranny were similar in design to the Gen 1 Stealth" I assume the "Gen 2" is the B2, but the post doesn't specifically say. Any difference at all between the B2 and B3 stuff? Does this mean that AE didn't change the tranny at all between the 2 and 3 series vehicles? EDIT: I'm told they are the same... which is what I figured. Last edited by chevy42083; 09-11-2007 at 06:21 PM. |
09-24-2007, 02:52 PM | #133 |
I wanna be Dave Join Date: Aug 2007 Location: JERSEY BOONDOCKS
What universals/axles are most commonly used with the Associated Stealth trannies? Would I have any problems using a Gen 1 rc10t stealth for a crawler?
09-24-2007, 02:57 PM | #134 |
I wanna be Dave Join Date: Apr 2005 Location: Vegas
| I used on for a long time. Make sure your outdrives are in good shape. When they get worn the diff gear will get eaten by the heavy torque loads.
09-29-2007, 04:44 AM | #135 |
Rock Stacker Join Date: Sep 2006 Location: ITALY
| help me....
i got this tranny, but i don't remember the manufactured,neither the models.. so i can't buy spare parts.. can u help me?? don't trust at the motor mount cause it's handmade... many thanks!!!!!! |
10-08-2007, 07:06 AM | #136 |
Pebble Pounder Join Date: Sep 2007 Location: denmark
damn a nice guide
10-21-2007, 05:40 PM | #137 |
Quarry Creeper Join Date: Oct 2007 Location: Pennsyltucky
Are all the rc10 trannys usable cause I just bought one off of ebay and it doesn't say stealth or anything. Only paid $16 for it.
10-21-2007, 05:59 PM | #138 |
10-21-2007, 07:45 PM | #139 |
This one? |
10-21-2007, 08:13 PM | #140 |
That is the OG 6 gear tranny. It will not work.:-( You'll need a Gen 1 Stealth or newer if you choose to use an Associated tranny. Sorry. |
