Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Heritage Crawlers > Tamiya TLT Crawlers
Thread: Tranny Guide
Old 12-17-2007, 11:13 AM   #161
toy4crawlin's Avatar
Originally Posted by 5150bronco View Post
what do you guys think about the R2 tranny?
thanks,
I drove it with a 55t integy lathe and no problems, crawled great with a 8 tooth, 6 cell sub C, Rebel2, Super
then sold it and bought a 2 speed,
added a Mamba max, Bm16, 8 cell and it broke, so i bought an Ax tranny, it's holding up great and I broke my axles with out the axial skipping a beat
toy4crawlin is offline   Reply With Quote
Old 12-17-2007, 03:54 PM   #162
So in a 2.2 scale rig, what is the ideal gear ratio (pinion, spur, and tranny gears NOT including the diff gears and tire diameter)?
I am playing around with an idea that will give me a 15.98:1 (when factoring in the gears mentioned previously).
duleonar is offline   Reply With Quote
Old 12-18-2007, 09:59 PM   #163
Hey thanks a lot for the feedback!
That is what i needed to hear...that is exactly what my setup was going to be so thanks for letting me know.
How did you like the 2 speed? What is the primary reason to use it in your opinion?
5150bronco is offline   Reply With Quote
Old 12-18-2007, 10:02 PM   #164
Originally Posted by 1beatjeep View Post
it about if you want to spend money
Okay. So is it worth the money......? or just go with the pede again?
what do you think...I am getting back into this now that i have a job.....so doing more research that is why i called you.....
Old 05-03-2008, 07:18 AM   #165
Default Size ???
I would like to know the width/height of the Stampede and AX10 trannys ???
TheHeadHunter is offline   Reply With Quote
Old 05-10-2008, 06:05 AM   #166
I joined the Band!
yeah me too. is the stampede tranny longer than the axial monting plate???
skullking is offline   Reply With Quote
Old 09-23-2008, 10:36 PM   #167
I have a n00b style question. Do you use the full Pede housing or just the gears.
Thanks
HappyCrawler is offline   Reply With Quote
Old 09-24-2008, 02:37 AM   #168
Thanks
yea, but i would go with axial or chop the heck out of pede.
Old 09-24-2008, 10:02 AM   #169
Ok. I'm going with the Axial AX10, but what chassis will that bolt onto without modification? I am, of course, going away from the stock chassis, but I need a recommendation.
Thanks
Old 09-25-2008, 02:30 AM   #170
Thanks
ya know, i just invested in artr axial and I am very happy. just depends if you want/like scale, comp, or basher type of crawler.
Old 12-23-2008, 09:26 PM   #171
Thanks for this thread. I picked up TLT axles and a "pede" tranny for a basher...I like the fact that it has one of the higher gear ratios. I'm looking for speed. I was also looking into the stealth, had a RC10 back in the late 80's when the stealth first came out and wondered if it would be a good crawler tranny...sure didn't make a pulling tranny worth a damb....
thanks again
squatch71 is offline   Reply With Quote
Old 02-01-2010, 01:26 PM   #172
I will have to do the math but I have a AX10 trans with a 55T integy and all that i have that fits together right now is a 24tooth on the motor and 78 tooth spur, what do you guys think?
Abednego is offline   Reply With Quote
Old 02-01-2010, 02:46 PM   #173
Keep it real
Tanis's Avatar
What battery voltage and tire size? Scaler or comp rig? How heavy?
If you are running tires under 5" tall on 3 cell lipo it should be OK, but bigger tires or lower voltage and it's going to stall out a lot easier if you have good traction.
Tanis is offline   Reply With Quote
Old 02-01-2010, 03:19 PM   #174
2.2 imex g hawgs, 3300 mah battery, no more then 5 pounds, scaler trail/mud bog truck. thanks
Old 08-13-2010, 05:13 PM   #175
Which one would be better? a peed trans or a hawk trans????
I was liking the hawk since its smaller & has an alum motor plate that i could easly make a biiger one to use a larger pinion gear. but I have to admit that I know very little about gear ratios..
I can post pics of the internals too if needed.
airdreams1 is offline   Reply With Quote
Old 12-28-2014, 11:56 AM   #176
Default Re: Tranny Guide
I'm looking at mounting a Traxxas transmission in my TLT, I'm keeping the stock chassis. what method is used to mount this?
The Bug is offline   Reply With Quote
Old 12-28-2014, 12:11 PM   #177
MODERATOR™
EeePee's Avatar
Stock chassis? Probably need to hack 75% of one side away and drill four mounting holes on the other side plate to mound the transmission. Motor on top. Can't say I've seen that done.
EeePee is offline   Reply With Quote
Old 12-28-2014, 04:10 PM   #178
I kind of figured that, I don't want to cut up my chassis, I guess I'll leave it as is thanks anyways.
