02-14-2007, 05:53 PM | #1 |
Pebble Pounder Join Date: Aug 2006 Location: High Point
| another problem..urg
ok, i tested my carawler today, just drove it in my yars, over 1 rock... it stripped the rear drive yoke, the set screw wont get tight enough to hold the pinion. is it because i am useing plastic universals, and jato shafts?should i use the 20 dollar aluminm ones, of drill the pinion to use the longer set screw... i have yet to break the front one, the rears keep breaking. i snapped an ear off the one on the trans, and the screws at the axle. i hope i didnt screw any thing up. |
02-14-2007, 06:37 PM | #2 |
Rock Crawler Join Date: Jun 2006 Location: Santa Rosa
i believe you are having the same problems that i had. You must drill all the way through the transmission outputs, and the axle pinions. And use the screw that came with the yokes. This is a sure way it wont come off. http://www.rcpics.net/view_single.php?medid=81490 http://www.rcpics.net/view_single.php?medid=81493 Sorry pics suck, but oh well |
02-14-2007, 07:31 PM | #3 |
what size bit did you use to drill the pinion, maby i will just bite the bullet and get the metal ones
02-14-2007, 07:34 PM | #4 |
3/32" bit drill the trans outputs and the axle inputs.
02-15-2007, 04:43 AM | #5 |
the trans are fine, but i broke the little ears off one side of the universal, on the trans...before it spun on the axle the same thing happend... gonna get the steel ones today, i hope i dont run into ne more problems
