Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Tamiya TLT Crawlers
Thread: Attention Nate!-three speed question.
Old 02-14-2004, 08:53 PM   #1
Highmark's Avatar
Default Attention Nate!-three speed question.
Figured I'd ask before I blow 80 bucks and start striping gears-is the Tamiya three speed semi tranny like what you used in you're dualy project very durable? I would like to run one with Jugg tires mainly because of the gear reduction (by my figureing a 60:1 threw just the T-case and tranny is possible). Whats you're opinion?
Thanks man!
Highmark is offline   Reply With Quote
Old 02-15-2004, 12:08 PM   #2
Default Re: Attention Nate!-three speed question.
I think that the transmission is a lot more durable then the transmission used for even the bruiser. The constant mesh gears make it easier to shift without grinding. For everything that i have used them in, the dually and the semi trucks, I think they are pretty good. There was a guy on RCMT that mounted the 3 speed to the front of a jugg tranny and from my understanding, that worked great. I dont think that i would make a 2wd say using jugg axles and tires hooked straight to the tranny, but if you add at least 3:1 gear reduction in the transfer case you should be good to go. I will post pics later of the t-case that i am going to used with my tlt axles.
Nate
sig_p232 is offline   Reply With Quote
Old 02-15-2004, 03:35 PM   #3
Highmark's Avatar
Alright thanks man! -I should have a fairly low reduction in the case useing the gears I plan on so hopefully everthing will be hunky doory. BTW did you ever get the dually back from RCCA?
Old 02-15-2004, 07:05 PM   #4
Last week, kevin said that he would be shipping the truck, but i have not recieved it, and he is horrible about emailing people back.
Nate
Old 02-22-2004, 01:12 AM   #5
I finally heard back from kevin and things got delayed, but it should ship in two weeks. He is even shipping me a box of magizines for the family members who want them.
Nate
Old 02-23-2004, 04:11 PM   #6
hey you should send one of those mags my way
jmirsberger is offline   Reply With Quote
Old 03-01-2004, 06:46 PM   #7
Highmark's Avatar
Like da freebies eh?
