02-16-2007, 08:16 PM | #1 |
Pebble Pounder Join Date: Jan 2006 Location: Evansville
| Great easy way for upper shock mounts pictures added
Use the ball end BF4 in the instruction manual. The have a 3mm threaded hole all the way thru them. I put a bolt thru the chassis with the threads sticking out and put a lock nut on it. Then used a 1/8" spacer then screwed the ballend on. Put the shock on and another lock nut. You get lots of movement and works alot better then fuel tubing. If you need a picture, let me know and I will post one this weekend. I am using maxx shocks.
02-16-2007, 08:31 PM | #2 |
Quarry Creeper Join Date: Nov 2006 Location: Lexington Park
pictures are allways better. its easier on the brain. thanks
02-17-2007, 12:17 AM | #3 |
Rock Crawler Join Date: Feb 2007 Location: In A Nut Shell
ya pic would help because im lost, sounds good though because the fuel tubing drives me nuts.
02-17-2007, 07:31 PM | #4 |
| Pictures
First pic. shows the pcs. on the 3mm bolt Second is everything snugged up Third shows shock slid on Completed. This set up works very well. There is a little bit of up and down play between the shock eye and the ball end but not much. |
02-17-2007, 10:12 PM | #5 |
Rock Crawler Join Date: Feb 2006 Location: Cutting Comms
My TLT kit only came with one of those BF4 ball ends. From what I understand getting a set of 4 can be costly/difficult. Heres something along the same lines that uses cheap, easy to locate parts. http://www.4wdthunder.net/Forum/index.php?topic=179.0 |
02-17-2007, 10:50 PM | #6 |
cool ill be doing that tomarrow if those are hard to find i have quit a few.
02-17-2007, 11:06 PM | #7 |
I wanna be Dave Join Date: Sep 2004
i like the "shock mod" that the guys at REIGN PRODUCTS recomends. heres a link to thier page and click on the pdf build up of the J2-tt. www.reignrc.com |
02-18-2007, 10:13 AM | #8 | |
Rock Crawler Join Date: Jun 2006 Location: Santa Rosa
Is it just because thier is a lot less binding?Thanks | |
02-18-2007, 06:43 PM | #9 |
| Correct
There is no binding at all thru the suspension cycle. I also like the idea of putting a traxxas rod end on in place of the eye.
