Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Heritage Crawlers > Tamiya TLT Crawlers
Thread: ILRCRC's Torsion
Old 02-22-2007, 08:06 PM   #21
Originally Posted by MAXIMUS
Excellent build so far. I think I'm finally inspired to start a second build just finished a tlt/sw2 but I want to start a tortion build. Thanks for the updates on your builld and keep those pics comming. By the way are there any drawbacks (besides the lack of articulation, of course) to tortions, I mean everyone just uses them for comps, are they not that fun to drive or somthing? One more quick question. With tortions being so light (crawler minus the chassis weight) couldn't you get away with a 45t or even 35t motor and still have the torque because it's lighter?
Actually, you don't need as much articulation as you think. They're not boring to drive, its just specifically a comp rig. Yeah, you can still take them out in the back yard to screw around with. They're designed with an extremely low center of gravity. They're actually not very much lighter than any other 2.2 comp rig because most people put weights in the tires or on the axles. Doing so allows for better traction, while keeping the weight as low as possible. As long as you dont add that extra weight, you probably could get away with a 45t or 35t motor.
ILoveRCRockCrawlin is offline   Reply With Quote
Old 02-22-2007, 08:10 PM   #22
Originally Posted by dezfan
Good job so far CJ!
Thanks Joe!
It would be done right now, minus the BL for now, but we were inturrupted on our way to the hobby shop. One of my step dads coworkers/fellow firefighters called him to come help him out because he might have had a broken leg. So, my stepdad radioed in to dispatch to have a rescue sent there and we went as well. We were about a minute and a half from the hobby shop, too. Turns out he has a broken femer and has to get reconstructed and pins put in. OUCH!
Old 02-22-2007, 08:13 PM   #23
Originally Posted by polyophio
OMG! I can't believe you actually did something.
Looks good. Keep it up.
More than you've done on your two rigs.
Old 02-23-2007, 09:14 PM   #24
I got some work done on it today. I got the collars so all the plates are secure now. I also go my bearings from R2J today with a little bonus. He had accidently put knuckles in the package. I already talked to him and theya are paid for. All thats left is getting these damn yokes on the tranny outdrive cups. I can't get a hole drilled through them to get the pin all the way through and no matter what I do they wont stay straight. All help would be appreciated with that.
Well heres some pics...
Old 02-23-2007, 09:24 PM   #25
Talking
you forgot your links
Krawler Freak is offline   Reply With Quote
Old 02-23-2007, 09:29 PM   #26
Oh damn. You're right!
Old 02-23-2007, 10:19 PM   #27
if i was you i would do a bta set up for your stearing it wont get hung up on rocks as much. if you want i can post pics of how i did my bta system on my knock off bmv!!! your rig is looking good!! also what i did to get my hole straight i ground down a flat spot on the tranny out puts and it helped a great deal!!
nitromtcrawler is offline   Reply With Quote
Old 02-23-2007, 10:34 PM   #28
Yeah, I was planning on doing BTA steering setup. I already have it planned out. I just didn't want to screw with it yet. I want to get it running before I do any other not absolutly needed mods. I'll try out grinding a flat spot, but I think I just need to drill deeper into the yokes. I was noticing that I only drilled to just after where the holes are for the pin to go. Thanks for the tip!
Old 02-24-2007, 12:04 PM   #29
Well its done for now. Still need to get an adapter plate for the BL motor. I'm going to do some test driving before I paint the chassis and mount the body. I think I'm going to try the battery on the rear axle. The front is too heavy and it cant pull itself up a vertical wall, of course thats testing on a hardwood floor and couch. I'm really happy with the low CG. Even with this mamoth 65t it can stand on its side with no problem. I've also noticed that the star shaped foams make for a bumpy ride.
Current stats are...
WB- 12.5" (comp limit)
Width- a little over 9.5"
Center chassis clearance- 3.25"
Under axle- a little under 1.5" once they are shaved
Overall height- ~6.5 without body
Ok, on to the pics....
Old 02-24-2007, 12:42 PM   #30
dezfan's Avatar
Looks good CJ!
dezfan is offline   Reply With Quote
Old 02-24-2007, 12:44 PM   #31
Looks good CJ!
Thanks. Do you think you could get a pic of your electronics arrangement for me? I need some ideas.
Old 02-24-2007, 01:14 PM   #32
Looks real good. You're going to love the hell out of that truck.
Did you countersink the screws under the tranny? If not, do so. It makes a world of a difference. You might want to also round out the bottom of the tranny plate just a little bit.
Cloak is offline   Reply With Quote
Old 02-24-2007, 01:16 PM   #33
I already do. Just driving it around the house is a blast. I can't wait to get it on the rocks now. If only we didn't have a foot and a half of snow.
Old 02-24-2007, 01:17 PM   #34
dezfan's Avatar
Sure.
Old 02-24-2007, 01:20 PM   #35
Sure.
Thanks.
I forgot to mention that I'm temporarly running a Moped and 65t with a 6 cell AA pack. Once I get the adapter plate I'll be running BL with 8 cell 2/3 AA pack.
Old 02-24-2007, 08:34 PM   #36
I got some more work done. Painted the chassis and got the body mounted. Many of you may recognize the body. Thanks Dez!
Old 02-24-2007, 08:36 PM   #37
Wow! You have been working your butt off on that thing. Nice job.
polyophio is offline   Reply With Quote
Old 02-24-2007, 08:39 PM   #38
Adilynsdad too!
braceysdad's Avatar
Dang Chris, you go. Great job
braceysdad is offline   Reply With Quote
Old 02-24-2007, 08:40 PM   #39
Thanks. Now only if I could get it on some rocks!
Old 02-24-2007, 08:42 PM   #40
Thanks!
