Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Heritage Crawlers > Tamiya TLT Crawlers
Thread: Red Traxxas links
Old 02-22-2007, 06:06 PM   #1
Default Red Traxxas links
What is the part number for these red Traxxas links I see everyone using for their lower links and steering rods? I have done alot of searching but cant find the part number so I get the right ones at the hobby shop.
Thanks
shawkins is offline   Reply With Quote
Old 02-22-2007, 06:17 PM   #2
They are links for the Revo the part number is 5319x for the red aluminum ones and 5319 for the black steel ones.
fireguy is offline   Reply With Quote
Old 02-22-2007, 06:23 PM   #3
the ones i use are traxxas #5318x
NoblesvilleKid is offline   Reply With Quote
Old 02-22-2007, 06:50 PM   #4
Both part numbers will work, The 5319 (x) is a little shorter than the 5318 (x). The 5319 (x) is 134mm end to end and the 5318 (x) is 137mm end to end. So it just depends on which ones you want to use.
Old 02-22-2007, 06:53 PM   #5
Keep it real
Tanis's Avatar
For the steering tierod you need the longer one.
Tanis is offline   Reply With Quote
