Regin K3-2S link setup using TLT axles. I'm the middle of an old school build using the Regin K3-2S chassis which I was given for free. Most threads with the Regin chassis is dead with no pictures. So do any of you have chassis pictures of your setup so I can get some ideas? I have built many TLT axled rigs over the years, mostly using custom chassis. Regin chassis is first for me. |
Re: Regin K3-2S link setup using TLT axles. I don't have any old pictures, but I remember it being kinda a janky setup with not much triangulation. if I remember correctly the bottom links went straight to the axle and mounted on the single hanger, the top links mounted straight to the top of the axle. I think I made a custom link mount to mount the tops to the center of the axle. |
Re: Regin K3-2S link setup using TLT axles. For now I have just made the mock up links, but there is not a lot of link mounting places available. https://hosting.photobucket.com/imag...080&fit=bounds |
Re: Regin K3-2S link setup using TLT axles. Looks how I remember mine, Caprinut. I remember having a truss with a center upper mount to cause more of a triangle. I also had my servo on the axle with a center mount. |
Re: Regin K3-2S link setup using TLT axles. @caprinut, I stole some pics from OSRC to show the truss and Dinky link I was referring to before... Quote:
Re: Regin K3-2S link setup using TLT axles. The uppers should mount on top of the axle and a two hole TLT bracket mounts on top of the upper. The shock mounts to the 2 hole bracket to lay the shock down for more travel and a better spring rate. There isn't much triangulation, but they sure did work good back in the day. |
Re: Regin K3-2S link setup using TLT axles. I’ve got two Reign K2 chassis rigs still built. Yes I’m using trusses on both axles. I can help out with whatever you need. |
Re: Regin K3-2S link setup using TLT axles. Quote:
