02-26-2007, 09:11 PM | #1 |
I wanna be Dave Join Date: Jun 2005 Location: KENNEWICK, WA
| Axle shimming?
I've been doing some searching and was wondering if anybody has done a write up on how to shim the axles to keep the R&P from becoming glitter.
02-26-2007, 09:27 PM | #2 |
Quarry Creeper Join Date: Jan 2006 Location: Winston-Salem
I haven't seen a write up on it. What are you wanting to know in particular?
02-26-2007, 09:31 PM | #3 |
Well I've been told a couple difrent ways to do it but one is confusing and the other is a shim between the pinion and bearing. So what's the right method and best? just thought it would be good for the newbs too so they don't get pushed away when they go out and destroy a diff the first time out.
02-26-2007, 09:58 PM | #4 |
You don't shim the pinion, you shim the ring gear. You push it sideways toward the pinion. You just need the right shim. I don't know which one it is, as I have never shimmed mine. On the other hand, I have only stripped 1 r/p in 8months of crawling, and it was over 2 yrs old.
02-26-2007, 10:01 PM | #5 |
Yea I don't understand that method I have the quick change axle method and dont see how the shim would stay if you pull the axle.
02-26-2007, 10:07 PM | #6 | |
02-26-2007, 11:30 PM | #7 |
Quarry Creeper Join Date: Oct 2005 Location: SoCal
| TLT R&P Shimming Ring Gear I use 4 shims, 2 on each side of the Ring Gear with no inner axle e-clips. The bearings on each side of the ring gear hold the shims in place when changing a broken axle. Pinion Gear I use 1 shim behind e-clip For shims I use Traxxas Fiber Washers 5x8mm part #1985. |
02-26-2007, 11:34 PM | #8 |
I built the axles and the first time out I snapped a rear in less than a hour, so I told myself when I replace it it's getting the inner clip removed cause I could have been up and running again with my spares. Oh well hopefuly them CVD's come out soon.
02-26-2007, 11:37 PM | #9 | |
02-26-2007, 11:43 PM | #10 | |
02-26-2007, 11:46 PM | #11 | |
02-27-2007, 11:13 AM | #12 | |
Rock Crawler Join Date: Apr 2006 Location: pasco,Wa
02-27-2007, 11:23 AM | #13 | |
I wanna be Dave Join Date: Jun 2005 Location: On the G-Train!!!!!
Just put 1 shim behind the pinion. This pushes the pinion out to the ring gear. Never had a problem since. | |
02-27-2007, 10:13 PM | #14 |
Quarry Creeper Join Date: Apr 2005 Location: The Garage working on a toy car.
| shims
Same here 1 shim on the pinoin so its closer to ring gear less play.
02-27-2007, 11:37 PM | #15 | |
Rock Crawler Join Date: Jul 2004 Location: OC, Oregon
02-28-2007, 10:14 AM | #16 |
Pebble Pounder Join Date: Feb 2007 Location: Woonsocket
Hey i'm a nb here. What exactly does shimming do? I mean by shimming it i guess you say you save the gears? Why does it screw the gears up?
02-28-2007, 10:42 AM | #17 | |
RCC Addict Join Date: Oct 2005 Location: rite here all along
02-28-2007, 11:51 AM | #18 |
02-28-2007, 08:18 PM | #19 |
ok i think i get it. I think i saw it in a post somewhere on here. It moves the gears upa little so that there is more "gear to gear". It moves it up more on the pin right?
02-28-2007, 11:31 PM | #20 | |
