Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Heritage Crawlers > Tamiya TLT Crawlers
Thread: Newbie question! Battery location?
Old 03-02-2007, 02:29 PM   #1
Default Newbie question! Battery location?
Sorry guys, just a quick question. Were do you mount your batt's on a tlt? I'm thinking upper front links?
Sorry, I've only had clods before.
Thanks for your time, Stu.
slipping_side_ways!!- is offline   Reply With Quote
Old 03-02-2007, 02:31 PM   #2
frank400's Avatar
on top of the front servo and links..
frank400 is offline   Reply With Quote
Old 03-02-2007, 02:32 PM   #3
Cheers, solid mounted on the servo? (cable tied)
Any pics would be great.
Old 03-02-2007, 03:08 PM   #4
Look on the TLT gallery to get some ideas
theshimonator is offline   Reply With Quote
Old 03-02-2007, 06:03 PM   #5
Part of battery mounting will depend on the chassis you are using and your intended purpose for the crawler. This is how I have mine mounted on my SW2 chassis:
I'm using a couple of left over parts from the original TLT kit and a battery bar from an RC18T. This method will only work with 2/3A's or LiPo batteries (or I suppose AA's if you built a pack out of them).
Overall, it's clean and easy to access the battery and has shown to not be detrimental to the performance of the crawler.
Wookiebiker is offline   Reply With Quote
Old 03-02-2007, 06:15 PM   #6
there is also a thread under the electronics section with a pack made of 2/3 a's 5 across the top of the servo and one hanging off of each end. cheap battery packs.com has made 4 of these for me and they are a very nice fit. and the front is not limited on articulation like a full size stick pack would create.
rcjunky3 is offline   Reply With Quote
Old 03-02-2007, 07:45 PM   #7
frank400's Avatar
look up bender and his build shaggin wagon in the tlt section..great info
