03-05-2007, 05:15 PM | #1 |
Pebble Pounder Join Date: Dec 2006 Location: Peoria, AZ
| Stock chassis build ?'s
I did search and didn't find what I was looking for. I'm building a crawler for my 8 year old son and I'm going to use the stock chassis for now. What links do you use for upper and lower for a 11-12" WB? Are there any you can buy that are the correct length or will I have to make them. I'd rather just buy em' if I can. Has anyone tried to shoehorn a stealth tranny into a stock chassis? That's the plan but I don't have the chassis yet to see what will have to be fabbed. This should prove to be a lot more complicated than building my bender chassis rig.
03-05-2007, 05:24 PM | #2 |
Quarry Creeper Join Date: Jun 2006 Location: Pinckney
Here's mine. I made my links, but it should get you in the ball park. Another run of the mill TLT based crawler |
03-05-2007, 06:09 PM | #3 |
Rock Crawler Join Date: Nov 2006 Location: Albuquerque
Here's another. I also made my own links. I run right at 12" for the wheelbase and my lowers are 4 1/2" from hole to hole. I cut about an inch off the bottom of the chassis and used stock holes for the lowers and made new ones for the uppers. Upper links are the stock TLT lowers adjusted for the preferred drive line angle. Hope this helps! |
03-05-2007, 07:41 PM | #4 |
Thanks guys. I guess I'll be getting some threaded rod and aluminum tubing.
03-05-2007, 08:57 PM | #5 |
Helps to actuallypost alink so you can see what I was talking about. Sorry about that! Here you go: Bronco on a Budget |
03-05-2007, 09:01 PM | #6 |
Pebble Pounder Join Date: Jul 2006 Location: SL,UT
| first tlt build heres mine. i used the stock tlt plates with a stampede trans. i listed the links in the thread as well for a 12.5 wb |
03-05-2007, 09:03 PM | #7 | |
RCC Addict Join Date: Aug 2006 Location: trying to find out what a TVuPer is.....
03-05-2007, 10:31 PM | #8 | |
