View Poll Results: how many degrees? | |||
1 | 0 | 0% | |
2 | 1 | 9.09% | |
3 | 5 | 45.45% | |
More | 3 | 27.27% | |
All the above | 2 | 18.18% | |
Voters: 11. You may not vote on this poll |
03-07-2007, 10:28 PM | #1 |
Quarry Creeper Join Date: Jul 2006 Location: Salem
| Axle clocking
Let me reword it. I am working on a new part. So if you could on YOUR rig how many degrees would you like to clock your axles?
03-07-2007, 10:37 PM | #2 |
RCC Addict Join Date: Sep 2005 Location: ...Here & There
It depends on the vertical seperation of your outdrives & your pinion. ^-v It also depends on the distance between your axle & tranny. <---> I don't know the degrees but... My rear driveline, is a RCH from being straight. Keeps the input out of the rocks!!! |
03-07-2007, 10:47 PM | #3 | |
Newbie Join Date: Sep 2006 Location: At the nuthouse!
03-07-2007, 10:51 PM | #4 |
Quarry Creeper Join Date: Jan 2007 Location: US
As far clocked as you can go without binding at full compression... atleast that seems like the right answer. That is the approach I am taking to my rig. |
03-07-2007, 10:53 PM | #5 |
My rear is pointing straight at the tranny, and the front I have clocked up a bit, I would say 5-10*. This gets the pinion up a little and I can slide the front end if I need to by just turning the tires back and forth.
03-08-2007, 12:19 AM | #6 | |
03-08-2007, 12:48 AM | #7 |
RCC Addict Join Date: Jan 2007 Location: San Jose
I would start with the pinion angle flat and rotate it up slightly, not much, so it is barely pointed up, but enough that you can see it is not flat. Hope that helps.
03-08-2007, 12:48 AM | #8 |
Maybe 3 degrees I believe....
03-08-2007, 09:43 AM | #9 |
Rock Crawler Join Date: Jun 2006 Location: Santa Rosa
i have my rear drivelin pointed straight at the tranny, my front is almost level
03-08-2007, 06:13 PM | #10 |
ttt
03-08-2007, 07:23 PM | #11 | |
I wanna be Dave Join Date: Jan 2006 Location: Albuquerque
03-08-2007, 07:28 PM | #12 |
becuase I changed the discription of the poll. Everyone one thinks I am asking for what I should do, But I am asking what would people like to do.
03-08-2007, 10:00 PM | #13 |
Newbie Join Date: Nov 2006 Location: Coeur d'alene
When I laid out the Roosterfish and machined up the clocked C's I set up for 18 degrees which keeps the drivelines well above the links and gives a straight horizontal coupling at the diffs with the shocks extended. If I were to do it again I would set up for about 14 degrees for this particular chassis configuration. The amount the pinion axis rotates during articulation depends on the relative lengths of the upper and lower links....and more importantly on the angle between the upper and lower links. C |
