BL gearin on stealth??? hey guys i need help... i am running a stealth tranny out of an RC10t (OG) and i have an OG revolver. i need some gearing suggestions.. i run a 12t pinion and 90 spur and it seems like it doesnt have enough power. it stall out on any ledge face. |
Add this upgrade from RPM. http://www2.towerhobbies.com/cgi-bin...?&I=LXEV49&P=7 It will bring your internal gear ratio to 2.65 to 1. This is practically the same ratio as the B4/T4. Then use an 87 spur and a 12 - 15 tooth pinion."thumbsup" |
i was hoping i wouldnt have to order more parts....:x is there something i could be missing in the programing of the esc or something? |
You don't have to have the RPM upgrade, but it helps. Try a 91 spur, it should work well. The RPM would be a nice upgrade in the future."thumbsup" |
i was just tryin to figure it out since i have a comp on sunday. i know you were running the og stealth w/BL. hell i sold you the stealth, but anyway what gearing did you run? is it possible my esc might be taking a $h!t on me? i have hear about the revolver having axle snapping torque, but havent seen it yet.:roll: |
I ran an 88/13 I think. Which Revolver are you running and how many and what type of cells? Here is a 90. |
well i have an original revolver from holmes. i have a 7 cell ib pack i am running right now but i also have an 8 cell mini t pack that i usually run. neither one makes a difference. oh and its a mamba 25. |
Definetly need to gear it lower. That was the issue I had w/ the Gen 1 Stealth and the R1. If you ever decide to sell that motor, I'm interested! |
i think i might keep it....;-) i will let you know if do decide to sell it. |
got her running right now... i simply swapped esc's and remapped it. i turned my start up speed up to medium wich i think solved alot of it. |
