03-05-2005, 09:33 PM | #21 |
Also..... SPUR GEAR FACES TO THE REAR! |
03-22-2005, 01:14 PM | #22 | |
Quarry Creeper Join Date: Jun 2004 Location: Fairmont
Toyofast, I'm still waiting to see how you mount your battery. Clark | |
03-22-2005, 07:52 PM | #23 | |
I wanna be Dave Join Date: Jan 2005 Location: Hueytown, Alabama
03-22-2005, 08:09 PM | #24 |
I wanna be Dave Join Date: Jan 2004 Location: Austin Texas
Rock, your best bet from where I'm setting would be to get some aluminum "L" channel and cut it down to fit over your servo as Toyo is sudgesting. From what I understand all of the link mount holes on the chassie are drilled for that set-up and it really does give you better suspinsion geometry in the long run. I've always run my trucks with that set-up just because it's easyer to control the role center then with the PWT type link mounts. That's what I'm thinking anyway Last edited by Highmark; 03-22-2005 at 08:12 PM. |
03-22-2005, 08:16 PM | #25 | |
Thats what I cant figure out....Mine is better than his. J/K Toyo | |
03-22-2005, 08:33 PM | #26 |
Also when you twist the axel, it doesnt stay centered....it should stay in the center of the chassis.
03-22-2005, 08:34 PM | #27 |
First off.... Everyone has different ways to mounting links, on the axles. From my knowledge there is no current aftermarket way to mount links on the axles. It seems as if Tamiya set it up to be pretty stuck with the stock mounting brackets and locations, sure you could make them work but not with the Bulu1 or Bulu2. Second... Building a crawler, especially a TLT axle based one takes time. Building a crawler is all trial and error. If you want a turn-key crawler, PM me with your money limit and I'm sure we could work out a plan. You need to be patient when building, serch and search more. It's hard to always post up the newest setups we install, it changes weekly due to trying to step it up a notch. Here are some current pictures of how my links are setup. Use the idea to build your own, or PM me for more info on having brackets built. This setup keeps everything straight and moving smoothly. Proper shock placement is key too... if you don't have them setup right you'll experience some binding. My setup is very smooth and keeps everything inline as it should be. Now, are you people having issues with building the truck or driving |
03-22-2005, 08:39 PM | #28 | |
BTW...You truck looks like sh*t. When you move your axels up and down do your axels twist or do they stay level?Like whe you compress the shocks. | |
03-22-2005, 09:53 PM | #29 | ||
Are you asking if the axles "sway" from side to side when flexing, like out of center alignment? Or are you asking if the axle "rolls" when flexing? When I say "roll", I mean the top rolls forward.... When my truck flexes everything stays as it should in a 4-link setup. Axle stays centered and everything moves freely without any binding. Proper vertical seperation of the links is critical to setting up the truck to work properly. The way mine is now, everything is on par with proper setup. If I helped, great... if I made is worse, too bad | ||
03-23-2005, 11:04 AM | #30 | |
03-23-2005, 10:03 PM | #31 |
If you really want to setup you links then do as these pictures show... this is all I have so don't ask for more. These are secret pictures taken of the #1 Bulu2 truck ever built by S-n-T Fab. It works super well. Buy some InetRC TLT servo mounts and do as in the pictures: |
03-23-2005, 11:59 PM | #32 |
Pebble Pounder Join Date: Feb 2005 Location: Watching U Sleep
| BULU 2....Done Yet!
My BULU 2 is going together as we speak and I just want to make sure that after all these posts it has been figured out and perfected And you will never guess who is putting mine together |
03-24-2005, 08:38 PM | #33 | |
When you guys are testing the flex on the rigs, are you testing it with or without your shocks mounted? Try doing it without your shocks mounted first. If it moves freely then your problem my be how you have your shocks mounted. Quote:
The BASIC way to set it up was stock Now, what I can't understand is how some of you can say that you have it mounted exactly like I do.... Have any of you actaully seen my setup in person? Has anyone taken measurements of my setup to see if it's the same? No. I went through about 6 different link mounting setups before getting to where I'm at now. I bet in another week it'll change again. It's just how the game is played. Change has to happen to stay with the lead pack. Check out how Dave has setup his new truck: "KNEEL BEFORE LORD VADER"!!! He has taken his setup past mine and his Bulu2 rig was freshly built too! I spy a 3-link setup like the other top dawgs in the 2.2 ORCRC class. I'm still running the old 4-link setup. :? I can only give so much information... | |
03-24-2005, 08:43 PM | #34 |
91mm on the top and 102mm on the bottom....I think there the stock traxxas turnbuckles. It has good artic. but it has to twist the top front link mounts to do it?
03-24-2005, 09:01 PM | #35 |
Rock Stacker Join Date: Nov 2004 Location: Gorgeous San Diego
you might want to switch your servo horn the other way around, so that your steering angles are not as bad. it will help with steering somewhat. Shane |
03-24-2005, 09:17 PM | #36 |
If I do that I will have to change the linkage setup....I run 4ws.
03-24-2005, 09:19 PM | #37 | |
P.S. I already have the 3 link setup.....Toyofast if you want pics let me know and I will PM you with them. | |
03-24-2005, 09:28 PM | #38 | |
Your upper links are not even the same, as far as how they line up with the axle.... Your trianglation needs work, perhaps that is some of the problem. Do this, put a 3mm-4mm wide spacer inside that "A" bracket, then tighten down the links. Or cinch down the "A"bracket until it closes together and the links get really close. Try different things.... that's all I/we do. And you do need to fix that steering setup.... Here are a few more images of my link setups that I have played with. Each setup worked but after doing one modification I'd take it for a spin outside on some rocks.. then change something again, then go back outside and see if I have made it better. | |
03-24-2005, 09:51 PM | #39 |
F*** it...I like my 3 link better and I know how to set it up.LOL I was just trying to figure out the 4 link.LOL I get awsome flex with 3 link anyway. Also, when I compress the shocks.....my axels stay level. |
03-24-2005, 09:57 PM | #40 | |
