03-22-2007, 05:19 PM | #1 |
Quarry Creeper Join Date: Mar 2007 Location: northern utah
| traxxas axles falling out!
hey guys i have a k2 chassis with tlt axles and im using the stampede axles, my problem is the stupid yokes keep coming off the tlt axles. how do you keep them to stay on ad straight? i have the set screws tight but they still wobble off! thanks guys
03-22-2007, 05:35 PM | #2 | |
Quarry Creeper Join Date: Jan 2007 Location: Kansas City
03-22-2007, 06:01 PM | #3 |
I wanna be Dave Join Date: May 2006 Location: Arlington, VA
dont remove the e-clip. what have you done to the pinion shaft? flat spot it on the opposite side if you havnt already. plastic or steel yokes? cross drill the pinion shaft and crosspin it instead of set screws.
03-23-2007, 07:36 AM | #4 |
Ok ya I was wondering if I needed to put a flat spot on the other side, I just have the plastic yokes for now and I did take that lip off it. Ill have to try the flat spot and drill a hole through it. Thanks guys
03-23-2007, 07:40 AM | #5 |
Rock Crawler Join Date: Sep 2006 Location: Denver
Just note that if you put a hole in the pinion and you have a pretty beffy setup or brushless the torque will eventually elongate the hole and it will break. It will take awhile but it will eventually will happen. Try the flat spot first and see how long it lasts. |
03-23-2007, 07:58 AM | #6 |
yeah, i was going to say i wouldnt cross pin unless you go with the steel yokes. although, pinions are expendable. |
03-23-2007, 08:04 AM | #7 |
If ya like to tear apart your axles |
03-23-2007, 11:56 AM | #8 |
Newbie Join Date: Mar 2007 Location: Mesa
I had the same problem. Go to steel yokes w/ 2 set screws and use some loctite. I have not had a problem since.
03-23-2007, 09:37 PM | #9 |
Quarry Creeper Join Date: Jun 2005 Location: quarryville
Pictures ??
03-23-2007, 10:37 PM | #10 |
Rock Crawler Join Date: Feb 2004 Location: Near Pittsburgh, PA
I used MAXX shafts attached to the stock drive cup: Easy method of mounting MAXX driveshafts |
03-23-2007, 10:39 PM | #11 |
ye ai saw that thread.. i did that on my front.. but it was such a pain i dont waanna doit to the rear lol
03-23-2007, 10:43 PM | #12 |
03-23-2007, 11:20 PM | #13 |
Newbie Join Date: Mar 2006 Location: in a house
you don't have to drill all the way through just use a drill bit and just give it a dimple for the set screw to set in, and don't forget the loc-tite ( it works on plastic also )
03-25-2007, 06:42 PM | #14 |
Quarry Creeper Join Date: Jan 2006 Location: lehi, Ut.
steel yokes and locktite is the answer......
04-03-2007, 10:12 AM | #15 |
RCC Addict Join Date: May 2005 Location: I live Here
what color/strenght lock tite do you use ? ? ?
04-03-2007, 10:58 AM | #16 |
blue is probably best if you use red you won't be able to get it apart
04-03-2007, 11:06 AM | #17 |
Pebble Pounder Join Date: Oct 2005 Location: Yorktown Virginia
i was having the same problem, but i went out and bought some allen inserts and did that to both sides. it is holding great! and i can also true up the yoke on the output.
