03-26-2007, 11:20 PM | #1 |
I wanna be Dave Join Date: Sep 2004
| To Much Weight On Axle ?
how much is to much for weight on a front axle ? im building my rig up and i planned on using some 2/3 cells for the truck but iam having trouble locating some loose cells and bars. so i thought about using a sub c 3300 pack,4 cells on bottom 2 on top on my fat rock servo/battery mount but with the BB's in my tires the front end is very heavy. i have a postal scale shuts off at 3lbs and the front end maxes that out. |
03-27-2007, 12:03 AM | #2 |
It depends...and it's a balancing act between front and rear. Also depends on the terrain, if it helps hillclimbing it usually hinders your descent. I'm running gp3300 sub-C pack up front and lead on the front and rear wheels. EDIT: See my post below...5 lbs. rtr give or take an ounce. Last edited by Natedog; 03-27-2007 at 12:42 AM. |
03-27-2007, 12:07 AM | #3 |
If the front alone weighs that much, you better stock up on spare axle parts, as you will put a lot of stress on them. I have run an 8 cell 3000 subc pack before, 6 on the front and 2 on the rear, but I didn't have any weight in the tires. My whole truck weighs 5.2lbs with an 8cell 2/3A pack.
03-27-2007, 12:39 AM | #4 |
Nor-CalRCRC Join Date: Dec 2006 Location: Monterey Peninsula
I run 8 2/3 A cells on the ft. and 2oz in each tire with another 2oz on each side of the axle inside the wheel. So,,,,,,,, 8cells plus 8 oz and it works pretty well. No axle trouble. Total rig weight about 5 3/4lbs. As far as batteries -http://www.cheapbatterypacks.com/ |
03-27-2007, 12:41 AM | #5 |
Just weighed my truck and it is five pounds ready to crawl...give or take an ounce. I used my bathroom scale, weighed myself with and without the truck. This scale is pretty accurate. I will use a large postal scale when I have time.
03-27-2007, 01:01 PM | #6 |
i just ordered a pack through holmes hobby. ill get a dry weight (no pack) of my total truck later. thanks guys. |
03-27-2007, 01:05 PM | #7 |
RCC Addict Join Date: May 2005 Location: I live Here
just placed an order for the same config you talk about 6 sc triangle shap 4 bottom 2 top for my basher xrc
03-27-2007, 10:13 PM | #8 |
my J2-TT weighs in at 5lbs (bathroom scale) with no battery or body.
03-27-2007, 10:18 PM | #9 |
Got those cells for you in the mail today On a 2.2 I would use smaller cells with tire weight. As far as how much weight to add, depends on where you crawl and how much your tires need to hook up. Takes a while to play with it and find the right balance. |
03-27-2007, 11:06 PM | #10 |
| thanks ! great price by the way.
03-27-2007, 11:57 PM | #11 | |
RCC Addict Join Date: Jan 2007 Location: San Jose
