03-27-2007, 04:40 PM | #1 |
Newbie Join Date: Mar 2007 Location: Scarsdale
| Tlt Axle/drive Shaft Problems
HEY GUYS...I AM RUNNING A TLT CRAWLER: BOUT 14'' WHEEL BASE -BENDER SW2 BLACK ANODIZE CHASSIS -TLT AXLES locked - TRAXXAS XL5 TRANNY LOCKED -INTEGY SHOCKS - 2.2 NARROWED MOABS ON HPI RIMS - INTEGY 55T LATHE MOTOR -ROBINSON 12T PINION MY PROBLEM IS...THAT I KEEP BREAKING THE DRIVESHAFT THAT GOES INTO THE DIFF SPOOL ON THE LEFT SIDE. IF YOU NEED A PICTURE TO SEE LET ME KNOW. WELL, THIS IS THE THIRD AXLE I HAVE BROKEN AND I AM PISSED...THIS PART IS HARD TO GET. THEERE IS A THIN PART ON AXLE RIGHT BEFORE KNUCKLE. ITS ALWAYS THE FRONT LEFT AXLE/DRIVESHAFT. I AM SICK OF BREAKING THIS PART AND NEED TO KNOW IF THERE IS SOMETHING I CAN DO. WHEN I LOOSEN SLIPPER, ALL THE TRUCK WILL DO IS SLIP ON TRANNY UNDER ANY HARD CONDITIONS.... |
03-27-2007, 04:53 PM | #2 |
I joined the Band! Join Date: Feb 2007 Location: San Diego
Picture will help.
03-27-2007, 05:26 PM | #3 |
RCC Addict Join Date: Aug 2006 Location: trying to find out what a TVuPer is.....
| so would a quick tap on the CAPS button. this is a common problem with the half shafts... check out rc4wd, they make a stronger version. www.rc4wd.com |
03-27-2007, 05:48 PM | #4 |
| picture: |
03-27-2007, 06:03 PM | #5 |
RCC Addict Join Date: Dec 2004 Location: HELL.....
yep, VERY common. i got a set of the rc4wd straight axles for the rear and will have a set of the cvd's when they are available
03-27-2007, 06:48 PM | #6 |
RCC Addict Join Date: Jan 2007 Location: San Jose
Please post a pic for us to see....... thanks! |
03-27-2007, 07:12 PM | #7 |
03-28-2007, 11:11 AM | #8 |
03-28-2007, 11:17 AM | #9 |
I wanna be Dave Join Date: Oct 2006 Location: Martinsburg WV
That's where they break, every time. Right now your only option is to replace them when they break. RCP is making CVD's that will eliminate this issue, but they are'nt ready to release them yet. I remember reading a thread about guys having stock TLT axles cryogenically treated to make them harder, but it's been a couple months ago. I don't think they came to any kind of workable conclusion with them. Your layout of what you are using does not sound unusual - if you were running a big outrunner I would'nt be surprised, but a 55t lather? Are you relieving the axles to get more steering range? It seems weird to me that you always break the left front... Last edited by Big Mike; 03-28-2007 at 11:21 AM. |
03-28-2007, 11:37 AM | #10 |
I wanna be Dave Join Date: May 2006 Location: Arlington, VA
how long did it take you to break those three? maybe somthings not right in your axle, does everything spin easily?
03-28-2007, 05:58 PM | #11 |
| i cut and trimmed front shaftr/cups for more steering and trimmed plastic gearbox. I work for Bruckner Hobbies and my boss, who has also gotten into crawling says that the cup has a sharp point near the slot for dogbon and on sharp turns is slowly cutting the axle, till it breaks. This makes sense. He says i can bevel the slots with the dremel to eliminate this. Maybe the front left cup is the sharpest and that is why i am always breaking that one.... Thanks for the help guys...BTW, know where i can get my hands on those cvd's..and just ho much stronger are rc4wd's shafts than stock...u think i would have same problem.... |
