03-30-2007, 10:22 PM | #1 |
Newbie Join Date: Jan 2007 Location: Lincoln
| TLT stock chassis cutting guide
I've got pretty much all the parts now for putting together a crawler. Only thing is that I can't seem to find any guides for cutting the stock TLT plates to accomodate a T4 stealth transmission. I'll be using some tmaxx turnbuckles with this setup. Anybody have any templates or even photos of how you cut the stock chassis plates?
03-31-2007, 04:49 AM | #2 |
RCC Addict Join Date: Dec 2004 Location: HELL.....
just go at it with a sharpie and a dremel. if you screw it up there are plenty of potential stock chassis donors
03-31-2007, 07:09 AM | #3 |
Rock Crawler Join Date: Nov 2006 Location: Albuquerque
I have a B3 in mine. Click the link in my sig for the build. There is another stock chassis/stealth build link in my build as well. I think that one uses a B4 and there are a few really good shots of the installation. Neither of us had to do much cutting to get it in. If you are going to install it in a laydown orientation, that's another story. You'll need to do more cutting for that. Good luck! |
03-31-2007, 08:29 AM | #4 |
Perfect! These are exactly the type of photos I was looking for! It looks like you cut off the bottom inch or so off the chassis plates, widened a couple of the slots on the left side and drilled extra holes for mounting options. I'm going to use this as a guide now that I have an idea for how much to cut off the bottom. Thanks and as emaxxjeremey said, I can always get more stock plates since they seem pretty cheap and common on ebay these days.
