Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Heritage Crawlers > Tamiya TLT Crawlers
Thread: how much is too much?
Old 03-30-2007, 11:49 PM   #1
Cool how much is too much?
ive been told this is highly unneccecary but i need a couple more opinions.
Nub-4-life is offline   Reply With Quote
Old 03-31-2007, 12:05 AM   #2
If it works, great! If it's too much, you'll know it. good luck
1tom2go is offline   Reply With Quote
Old 03-31-2007, 04:09 AM   #3
I lost my vendor privileges
as long as it is controllable it will be O'TAY.
doesnt look like it would be though.
my 2 pennies.
clodstall is offline   Reply With Quote
Old 03-31-2007, 05:56 AM   #4
i had a nylint that i modded to do that and then when it did go to fll flex it didn't return so i think you might end up with that
theshimonator is offline   Reply With Quote
Old 03-31-2007, 12:59 PM   #5
Cool oh
i just gota new chassis and this is about normal articulation but it can go a lil farther im the one that doesnt have a body K2-3L
Old 03-31-2007, 01:45 PM   #6
Originally Posted by Nub-4-life View Post
ive been told this is highly unnecessary but i need a couple more opinions.
it will get you into trouble in certain spots. There really is little to no place that 90 degrees of arti. will help, only hurt.
But hey, it is your rig- if you like it... roll with it.
mrpink is offline   Reply With Quote
Old 03-31-2007, 02:24 PM   #7
Default got flex?
looks like it would be hard to run a body with that flex! my 2 cents!
bezrq is offline   Reply With Quote
Old 03-31-2007, 02:29 PM   #8
Cool
yeah with that old chassis that has 90 is impossible to mount a body on. well its possible but my wheel rubs everytime i articulate. like i said now i habve a K2-3l and it is much better
Old 03-31-2007, 02:40 PM   #9
Big Mike's Avatar
Whoa - waaaay too much!
That much articulation will make it easier to get stuck in tight spots.
Big Mike is offline   Reply With Quote
Old 03-31-2007, 03:16 PM   #10
i dont thing that is good man... if you can hook up servos to the axles to pull them down to limit the flex, then i would do that!
DJEEPER is offline   Reply With Quote
Old 04-03-2007, 06:22 PM   #11
Sorry for posting here about a Clod, but the issue is pretty much the same. My Clod chassis will articulate just like that, no shafts to bind though, but I'm thinking about adding some fuel tubing or similar to the shock shafts (I'm using the gray bodied, red springed Maxx shocks) just like the stock Clod has on it's dampers to limit things down to something more reasonable. Any thoughts?
LAV25 is offline   Reply With Quote
Old 04-03-2007, 06:25 PM   #12
yep. move to clod forum.lol
j/k limit it you will tell a difference. trust me.
esier to drive when you can control it.
