03-14-2005, 08:33 PM | #21 | |
Rock Crawler Join Date: Mar 2005 Location: Dude on my dirt bike in SoCal!!!
thanks so much man. LOL look at this Quote:
108 for upper LOL massive downword angle on axles LOL. I got what u meant man. | |
03-15-2005, 06:51 AM | #22 | |
Quarry Creeper Join Date: Jan 2005 Location: Carlisle, KY
03-15-2005, 04:07 PM | #23 |
OOO wow super intresting. Never seen that b 4. why did u decide to do this?
03-15-2005, 07:54 PM | #24 |
Quarry Creeper Join Date: Jan 2005 Location: Crafty mexicans and your glass candy...
longer upper links rotate the axels to there is a less extreme pinion angle, and since to go the same distance, as the lowers, with the triangulated links they have to be longer.
03-15-2005, 07:56 PM | #25 |
Good deal. I c it makes sence now. LOL thanks so much Hey and how much articulation do u get out of that set up
06-19-2005, 08:19 PM | #26 |
Hey is this chassis a max climber or rock buster? also where u get ur pede tranny
06-19-2005, 08:56 PM | #27 |
Holy old thread Batman!! It was a rockbuster chassis, and I got my tranny from a whole stampede that I got on eBay. |
07-02-2005, 02:44 PM | #28 |
hey what rims are those and do you have n e axle wideners on there?
07-03-2005, 08:02 PM | #29 |
Newbie Join Date: Apr 2005 Location: anchorage
Nice job! I was curios...when you buy a stampede tranny does that come with everything you need or do you still need to buy gears? Also does anyone have the part number for the tranny?
07-03-2005, 09:16 PM | #30 | |
Quarry Creeper Join Date: May 2004
look in the sticky on tlts, i believe the part numbers are in there. | |
07-03-2005, 09:36 PM | #31 |
Hey open this file for all the part numbers... http://www.traxxas.com/products/elec...ans%20assy.pdf |
07-04-2005, 05:11 PM | #32 |
Quarry Creeper Join Date: Jun 2005 Location: quarryville
what did ya do put the motor and tranny off a rear wheel drive truck in there sideways. im doing that with my radio shack crawler build up traxxas rustler motor and tranny going front to back like yours is and a radioshack trucks axles and some of the chassis |
07-04-2005, 08:25 PM | #33 |
y put it in sideways so both the front and the rear axles can get power int really the only possible solution!
08-31-2005, 07:00 PM | #34 |
Newbie Join Date: Aug 2005 Location: Fresno
Old thread but I wanted to see if you could post some pictures of the tranny close-up? I don't see any problem getting it to fit in there but I noticed that your motor is mounted so that it's pinion is powering the diff it looks like and then you have a sepreat pinion powering the spur?!?!? It may have been the picture or it could just be that I'm going crazy but I know that you did something different than just shaving it and ploping it in. Picts. or just explain what your motor's pinion is powering and I'll get the rest. Thnx. |
08-31-2005, 07:45 PM | #35 |
why it looks like he is powering his diff as you say is because he has an extra gear reduction unit in there called the gd600... you can see it in the 5th pic... its the oval off the motor down to the right
08-31-2005, 09:49 PM | #36 | |
Diggin' the new SCX10 II! Join Date: Mar 2004 Location: Norcal
I have locked my TXT diffs with both and the KWIK turns to powder eventually. | |
08-31-2005, 11:13 PM | #37 | |
09-01-2005, 07:08 AM | #38 | |
09-01-2005, 06:20 PM | #39 |
ya neither have i i have locked my old center stock diff my new pede diff and the axle diffs and havnt had a prob..
09-15-2005, 09:52 PM | #40 |
Pebble Pounder Join Date: Aug 2005 Location: Stockdale, PA
I have a few questions for you. You swapped the metal brackets around on the axles with the triangle one on top and the one that was there on the back of the axle, right? And the lower links mount to the bottom of the one on the back, along with the shocks on top, and the upper links mount on the triangle one? I'm going by the pic you posted that shows how you use that fuel line tubing.
