![]() | #361 |
Quarry Creeper Join Date: Apr 2012 Location: Missouri
Got my winnie on TLT's ![]() ![]() |
![]() | #362 |
Quarry Creeper Join Date: Aug 2005 Location: Jefferson City
Here's mine. Same TLT axles since 2005! ![]() Specs:
Build thread can be found HERE ![]() ![]() ![]() Video - Goin' Up a Wall |
![]() | #363 |
Newbie Join Date: Nov 2008 Location: Monroe
My second TLT build , first 1.9 scale. Proline ambush CGR 3/8, 1/4 and 3/16 inch brake line cage and bumpers Square tube frame RC4WD delrin TLT axle housings RC4WD straight axles rear JB weld lockers Tamiya leaf springs front ,4 link rear Axial trans and 27 turn motor Mamba Max Pro Gens Ace 3s 1300 lipo Axial simple light controller Proline HID light buckets 11.25 wheel base, 8.25in tire width. weighs 5lbs 7oz ![]() ![]() Last edited by Di$c0; 05-08-2016 at 09:37 PM. |
![]() | #364 |
My first TLT build Proline Baja VW RBX laydown chassis 1/4 by .49 wall aluminum tubing links with Revo ball ends Tamiya dark impact front wheels and masher 2ks RC4WD straight alum axle RC4WD straight axles rear JB weld lockers Traxxas trans and 12 turn motor Mamba Max Pro Gens Ace 3s 1300 lipo 12.5 wheel base weighs 4.59 lbs 2013 TTC winner Jim's Pit Ruston, LA. ![]() ![]() Last edited by Di$c0; 07-06-2015 at 01:41 PM. |
![]() | #365 |
Quarry Creeper Join Date: Jan 2007 Location: Isanti, MN
I just pulled this old thing out of the closet: ![]() ![]() ![]() ![]() That's an old Gopher Tube chassis. It has aluminum body panels and a somewhat crude aluminum battery guard on the front axle. It is running droop suspension with Traxxas shocks and very soft springs under the piston that came from The Crawler store to help with stability as the tube chassis combined with normal shocks makes it quite top heavy. It has an old Losi XXX-T stadium truck transmission modified to work in a crawler (I was a kid without a real job at the time). It has a Mamba Max ESC I stole from that XXX-T of mine (I was sick of just zipping around a field with it, don't regret it one bit). It is running a 55T Integy motor and an HS-645MG Hitec servo. It has the cheap AM radio and receiver that came with the RTR XXX-T 8-10 years ago LOL. The suspension links and steering links are traxxis ends on some threaded rod from the hardware store with an automotive brake line sleeve over the threaded rod. The servo mount/ battery plate was from either The Crawler Store or RC4WD (I forget which). It has Traxxas driveshafts. The rims are some of the first beadlocks from Axial (I won them in a raffle with my local crawler group). There is some lead weight coiled inside the Rim where the axle goes (Not inside the tire though). The tires are Losi Rock Claws. She never won a comp but she did decently, especially for a high school kid that only got to crawl on rocks a couple times a month due to lack of transportation. |
![]() | #366 |
Quarry Creeper Join Date: Apr 2012 Location: Toronto
This is my TLT 1.9 scale comp work horse. TLT Axles Front Axle: RC4WD Delrin housing, locked diff, MIP CVD's, High Steer Knuckes Rear Axle: Aluminum Lock outs, stock internals TCS X-trail Chassis, AX10 tranny, MIP Drive shafts, 45T Lathe Motor, Proline shocks w/Team Associated B4 rear springs, 60W oil all around, Sidewinder V3 ESC, running 2S batteries (sometimes 3S but low MAH limits torque), Gear heads wheels, Pitbull Rockbeast tires, spektrum s8000 servo, glitch buster. Weight: 6.5Lbs RTR This truck spanks hopped up SCX10 truck all day long and is bullet proof!!! ;) (Sorry, pics are a bit old and missing MIP drive shafts and lock outs) ![]() ![]() ![]() Last edited by joe.bielski; 02-24-2015 at 08:18 PM. |
![]() | #367 |
TLT1 DEADBOLT 3/8 tubing chassis Tamiya Leaf front, 4 link rear Integy 35t lathe motor MMP esc with 11.1v GForce 2200mah lipo RC4wd CVD front axles Rc4wd stainless straight axles and rear alum housing RC4wd rear shocks Axial Deadbolt lexan Axial 1.9 Krawler TA on Tamiya Highlift wheels Axial tranny and rear driveshaft Traxxas front driveshaft and ujoints ![]() ![]() Last edited by Di$c0; 06-17-2016 at 10:56 PM. |
