Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Heritage Crawlers > Tamiya TLT Crawlers
Thread: Project Frankenstein
Old 03-13-2005, 10:29 AM   #1
Default Project Frankenstein
ok My project is finally complete,
Its called project frankenstein because its got parts from every car i own,
(and some i dont )
tlt (axels)
stampede ( tranny, shocks, shafts, wheels, servo saver, body mount, tires)
Hpi nitro rs4 3 ( steering dampner, body mount)
Tamiya tl-01 (motor, soon to be installed)
All of them donated electronics
cars idont own:
T-Maxx ( turnbuckles)
Revo (pushrods)
i dyed my wheels and softend the tires
then i took her for a test run
(but im having shaft problems)
Any way here are the pics,
the electronics are zip tied on because im out of servo tape
Frkan is offline   Reply With Quote
Old 03-13-2005, 01:30 PM   #2
cool truck....crazy mounted electronics
rcbif is offline   Reply With Quote
Old 03-13-2005, 01:44 PM   #3
Lower the battery, move the steering tie rod to the top of the knuckles, get rid of the rear bumper, get a servo horn and a better servo
CustomCrawler is offline   Reply With Quote
Old 03-13-2005, 01:49 PM   #4
Does that shock on the axle help the bump steer? I was gunna do it but didnt think it would make a difference.
Janke is offline   Reply With Quote
Old 03-13-2005, 03:27 PM   #5
Yeah, definately move that battery. You may want to try to put it up front somewhere, it will help with hill climbs, being that all that weight is closer to the front axle. Cool truck, none the less.
superdenk is offline   Reply With Quote
Old 03-13-2005, 04:44 PM   #6
that battery position and th electronics are just temporary. Im gonna get a saddle pack and put it low in the chassis side plates right now there isnt really a way to move the stick pack to the front. ill get a new battery later because im poor right now
Old 03-13-2005, 05:26 PM   #7
nice crawler
ILoveRCRockCrawlin is offline   Reply With Quote
Old 03-16-2005, 06:43 AM   #8
once again, does the shock on the steering do anything??
I've seen it a couple times but never knew if it helped anything
jwrape is offline   Reply With Quote
Old 03-16-2005, 09:41 AM   #9
Diggin' the new SCX10 II!
badger's Avatar
You pretty much nailed it.
Can that thing even turn with that shitty servo that has a servo saver and a shock attached to the steering?
I think you should call it "Project Gettostein" .
badger is offline   Reply With Quote
Old 03-16-2005, 02:47 PM   #10
well, as far as i know the shock just makes the steering smoother. The truck does turn, im sure it wouldnt be as good as some other rigs but that servos the only one i had lyin around
Old 03-19-2005, 10:05 PM   #11
well whatever that shock does it makes the whole truck look really trick
Mike-63 is offline   Reply With Quote
Old 03-21-2005, 03:59 PM   #12
well i worked on it a ton this weekend and have a little update.
I extended the chassis, made upper link mounts, put in my tamiya silver can motor, along wit ha 12 tooth pinion and a 90 tooth spur. I also pilaged the chassis braces from my pede to make some beefy body moounts.
i also painted this bronco body.
oh and do you guys think my motor/gearing setup will work well????
Old 03-21-2005, 05:30 PM   #13
looks great. I like the shock idea but dosent it make it a bit harder to steer? and are you getting ride of the stock motor? oh and nice body mounts...bet those wont be breaking soon lol
Old 03-21-2005, 05:47 PM   #14
the stock motor is better than the one i ad in it before and has a lot of tourque so thats why i put it in.
