04-26-2007, 06:34 PM | #1 |
I wanna be Dave Join Date: Apr 2005 Location: Eastern WA
| Steering issues?
My TLT has a ST125 servo, it turns 180 degrees right? when pluged in it goes about 45 each way, 90 degrees total from left to right. Well I cut my stub axles for my TLT to turn sharper, that works but my servo/linkage setup wont allow. I got the linkage on the Right Front knuckle up to servo (I put it so its got a linkage thats longer, isnt it better?) ..................__________...................... .................|...........O....|............... .... ...__...........|__________|........__........ ..|_|.....................................|_|..... ... .................................................. ..... front right knuckle...................Front Left knuckle ^^^^^^^^^^^from driving seat^^^^^^^^^^ |
04-27-2007, 12:48 AM | #2 |
I wanna be Dave Join Date: Jun 2005 Location: KENNEWICK, WA
no it dosn't turn 180* it only dose 90*, and why are you doing that funky chicken scratches when you have a star and know how to post pics? |
04-27-2007, 01:52 AM | #3 |
MWRCA'er Join Date: Apr 2004 Location: Machesney Park IL
If you are not getting enough steering throw you simply need a longer servo horn.
04-27-2007, 06:54 AM | #4 |
I wanna be Dave Join Date: Oct 2006 Location: Martinsburg WV
Depends on your transmitter. What are you using? The servo will only throw as far as the transmitter tells it to. Usually 90 degrees. I did the standard knuckle and axle modifications, and discovered that the servo would not push the knuckles as far as they could go, I still had more room to turn farther. So I also modified the case of my TQ3 to obtain the rest of the range of steering. It's pretty easy, just about anyone could pull this off. Pull the cover off of the center of the wheel and remove the screw. Pull the wheel off it's axle, and you'll see stops built into the case and back of the wheel to limit how far it is allowed to turn. I removed about 1/8" to 3/16" of material from the stops in the case, so the wheel can turn a bit farther. Now my steering has full lock-to-lock range. The knuckles will turn all the way into the axle, and my 2.2 Moabs just barely touch my shocks at full lock (and they're mounted pretty far inboard, on the links) and I have'nt modified my stub axles at all. Last edited by Big Mike; 04-27-2007 at 07:01 AM. |
04-27-2007, 07:52 AM | #5 | |||
04-27-2007, 05:19 PM | #6 | |
Rock Crawler Join Date: Apr 2004 Location: North GA
All servos do this...normal servos only rotate 60-90* under power though. One way to gain a bit of steering is to mount your links as far in (closest to the axle) on the knuckles. If you are running the stock plastic knuckles, this isn't an option unless you want to drill new holes further in on the knuckle arm. -Destroyer | |
04-27-2007, 05:30 PM | #7 |
Doesnt that mess with the laws of leverage (servo throw)
04-27-2007, 10:05 PM | #8 |
Yep, more travel at the expense of leverage.
