Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Heritage Crawlers > Tamiya TLT Crawlers
Thread: My tlt build
Old 12-26-2006, 11:44 PM   #1
Default My tlt build Chassic pics UPDATE ON 3rd page 1-18-07
Ive said I would make a build thread last week and will today Since i got some stuff in the mail
I have on the truck
Traxxas links
Moab 2.2 tires
Hpi wheels
45t lathe motor
traxxas 2055 servo (front
hitec hs-322hd servo (rear
Unimoger link mounts
traxxas tq rx and tx
Y connector
4 tmaxx shocks
and A metal body pinned on general lee body (temp body i was bored on saturday ok)
The body is just for now i was bored as ever when I did it
Tommorrow i am going to make the driveshafts for until I send double J the money for my Vertical smile chassis.
The servos Are temp also I need to order the moped esc still.
Also I am aware that it is top heavy because of the body and needs to be lowered but i'm doing that tommorrow
Link to my tlt gallery
http://s146.photobucket.com/albums/r276/Tlt_Gallery/
Brandon M is offline   Reply With Quote
Old 12-26-2006, 11:58 PM   #2
TLTCrawlin's Avatar
Good start, check out a AI runner esc (18+ turns, run a 55t lathe, and one 645 servo) the esc is waterproof also, and only 34.99 from tower (five more than a moped but waterproof)
TLTCrawlin is offline   Reply With Quote
Old 12-27-2006, 12:03 AM   #3
looks like you have a good start
Im using the stock uncut chassis and if you move your shock mounts towards the center two holes you will get a lot more flex
with my little softer springs i can get 90 degrees of flex
and you also need to move your tie rod to the top (Gives more clearance)
oh yeh im diggin the sheets
jigolbeep is offline   Reply With Quote
Old 12-27-2006, 01:52 AM   #4
Thanks for the comments a couple minutes after i posted this I lowered it the flex sucked then I moved them into the inner mounts and it gets like 85o flex
Crap looks like I need to get some axel wideners to my need list stuff rubs now
Edit heres a pic i just took
Old 12-27-2006, 04:04 AM   #5
I noticed that you triangulated the upper linkes, with the point of the triangle near the servo region...
does it make a difference whether you triangulate it there or triangulate it inside the chassis??
just wondering
thanks
-james
james399 is offline   Reply With Quote
Old 12-27-2006, 05:03 AM   #6
I lost my vendor privileges
yep.
clodstall is offline   Reply With Quote
Old 12-27-2006, 01:15 PM   #7
Yeah it did It got my COG lower and alot more flex
I just took the body posts off and wheels and took some pics THis chassis isnt staying for long Im ordering a Vertical smile chassis later this week
Here are more pics
Also In a little while im going to acehardware to get some tubing to make driveshafts for until i get another pede tranny
Old 12-27-2006, 01:22 PM   #8
Slow_Joe's Avatar
where did you get the general lee body from?
Slow_Joe is offline   Reply With Quote
Old 12-27-2006, 01:25 PM   #9
Walmart
Its off a 1/18 scale diecast car I drilled the holes in the body Its just for now I wount be using it because it makes it top heavy
Old 12-27-2006, 03:42 PM   #10
IMO and being a complete newb
I would change the springs to softer ones
or
get some longer shocks that are ajustable like mine i think this will get you more articulation
could you post a pic of each axle flexing separatly ? ? ?
thanks for following my build i will keep posted on yours
chivas72 is offline   Reply With Quote
Old 12-27-2006, 09:03 PM   #11
Yeah I will after I finish locking my pede tranny I just got. i am going to order the shocks you got What mm are they and who did you buy them from?
I mouned a pede tranny I didnt cout out the other chassis plate yet. here it is sofar
Old 12-27-2006, 09:46 PM   #12
looks good. nice flex
TREE is offline   Reply With Quote
Old 12-27-2006, 10:08 PM   #13
i picked up 3 feet of 6-32 rod today Tommorrow im going to Autozone to buy brakeline!
Old 12-28-2006, 08:53 AM   #14
110 mm shocks from run2jeep @ Jp Custom Rc's he is in the Vendors section
Old 12-28-2006, 09:00 AM   #15
Thanks my next 50 bucks Are going for shocks
Today I am going to cut out my chassis for a pede tranny foruntil i buy a vertical smile
Old 12-28-2006, 10:11 AM   #16
loooks good!!
andres-tavares is offline   Reply With Quote
Old 12-28-2006, 10:56 AM   #17
Originally Posted by andres-tavares
loooks good!!
Thanks I have it asll apart now
Old 12-29-2006, 11:12 PM   #18
i got an xl1 traxxas esc for now?
Old 01-02-2007, 10:52 PM   #19
Ordering my chassis tommorrow!
might pick up a couple things from the hobby shop tommorrow
question I want wideners but what ones should I get I dont want alot wider but i want it somewhat wider
and should I go with fat rock c's or wideners first?
Old 01-02-2007, 10:58 PM   #20
the axle C's are kick a** and that is a part that takes a pretty good beating if you don't mind some cutting and grinding go for them you can't beat the price and they really toughen up a weak spot on the axle.IMO Blackfoot axles are the cheapest way to get a little wider without completely screwing your steering and just a note about lrp AI runner esc's they have a 3 second reverse delay i love mine but it takes some getting used to...
axle c pic...
pvtjrt01550 is offline   Reply With Quote
