04-03-2005, 09:37 AM | #41 |
Quarry Creeper Join Date: May 2004 Location: Hartford, Connecticut
Outcast, absolutely great work!!!!! I really dig your 3-link design. Perhaps you could make a post with pics and some more info on making something similar? I'd like to do that to my TLBruiser. Thanx for sharing and again; great work!
04-04-2005, 10:35 PM | #42 | |
Pebble Pounder Join Date: Mar 2005 Location: Kelowna, B.C., Canada
Prolly sounds worse then it is, but it is really easy to make up links this way... | |
04-05-2005, 04:20 PM | #43 |
Newbie Join Date: Apr 2005 Location: Thornton
very cool I like that shock setup.
04-06-2005, 08:12 PM | #44 |
RCC Addict Join Date: Jun 2004 Location: Bruiser Heaven!!!!
hey outcastrc. i have a Q. too ask, how well does the 3-link work, and does how much suspesion travel does it have, please help.
04-06-2005, 10:51 PM | #45 | |
04-07-2005, 08:39 AM | #46 |
thank you for your help.
04-07-2005, 11:31 AM | #47 |
Quarry Creeper Join Date: May 2004 Location: Neosho
Outcast - Looks fricken awsome! I think you should put in a full roll cage. One thing I would do is weld all the floor pieces together. It would be all one piece and stronger too.
04-07-2005, 01:39 PM | #48 |
Rock Crawler Join Date: Nov 2004 Location: Thats a Good question
as said many times, its freaking sweet. keep up the great work.
04-08-2005, 01:21 AM | #49 | |
To weld the floor I would have to TIG weld it and any form of welding is far beyond my capabilities... | |
04-10-2005, 12:17 AM | #50 |
Well here is its first full cage. I am not sure if I like it or not. But I can always make another one |
04-10-2005, 12:57 AM | #51 |
Quarry Creeper Join Date: Aug 2004
it still strikes me the with the amount of detail you hand work for your rigs! looks good to me. but i haven't seen many 1:1's with their tps off. |
04-10-2005, 03:25 PM | #52 |
that looks awsome and great work to and are going to paint the cage to mach the body.
04-12-2005, 12:48 AM | #53 |
I decided to modify this cage and see where it would get before I started a whole new one. It def. looks better now that the door area is smaller. The cross adds something to the cage as well. While making and soldering the cage isn't difficult at all, trying to make it look good sure is! Thank goodness when I am done its going to be painted... |
04-12-2005, 12:25 PM | #54 |
Rock Crawler Join Date: Aug 2004 Location: Saugus
Excellent work! Once this is done, you should send pics to RC Driver showoffs and win yourself a subscription .
04-18-2005, 09:40 PM | #55 |
Next small update: I found a driver! Its none other then lovable Sam, the Hobbit! He was the only semi normal looking charactor that was the right size. If you notice I had to amputate! For a super posable figure you would think he could sit in a car right? WRONG!!! Its the one pose he can't do! So he's been given the proper drugs and then the legs came off. Once some surgery is done on his hips he will be patched back together. Then he should be able to sit in the proper position. I haven't told him yet but his feet are too big! I found a certain doctor who said he can shrink them for the proper fee. (Under the table of course) I don't think Sam will ever forgive me but they need to go and some boots added. While I was at it I lowered the Cruiser with some larger touring car springs. While its not as impressive as before. The steering link issue is gone. I actually have to get the s-link out of there for a straight one. Which is now parallel to the axle link. The tires don't rub under articulation, tho now the springs fall out everytime I touch it. I am going to at least capture one end. I might use a trick a buddy does on his full size trucks and leave the other end un-captured. And have a cone on the sping mount to allow the spring to slide back into proper position. A couple tests are in order anyways to see which way is best. Anouther positive is the driveshafts no longer to so badly angled. So they should last much longer. The rims are coming off in favor of OFNA rims. They have more offset and actually look like a rim an offroad truck should have. They should be here this week. http://www2.towerhobbies.com/cgi-bin...?&I=LXCAN0&P=7 With the help of Rikpal I have done some gearing math and right now as it sits its 55.92 in 1st, and 34.73 in 2nd. I am not sure if this will be an acceptable ratio with the 19 turn motor or not. I think I am going to order a couple GD-600's just in case anyways. I may back order a lathe motor as well. I can always use the parts in my next project anyways... Last edited by outcastrc; 04-18-2005 at 09:42 PM. |
04-18-2005, 09:43 PM | #56 |
the pics don't work
04-18-2005, 09:48 PM | #57 | |
04-18-2005, 10:19 PM | #58 |
The page cannot be displayed The page you are looking for is currently unavailable. The Web site might be experiencing technical difficulties, or you may need to adjust your browser settings. -------------------------------------------------------------------------------- Please try the following: Click the Refresh button, or try again later. If you typed the page address in the Address bar, make sure that it is spelled correctly. To check your connection settings, click the Tools menu, and then click Internet Options. On the Connections tab, click Settings. The settings should match those provided by your local area network (LAN) administrator or Internet service provider (ISP). See if your Internet connection settings are being detected. You can set Microsoft Windows to examine your network and automatically discover network connection settings (if your network administrator has enabled this setting). Click the Tools menu, and then click Internet Options. On the Connections tab, click LAN Settings. Select Automatically detect settings, and then click OK. Some sites require 128-bit connection security. Click the Help menu and then click About Internet Explorer to determine what strength security you have installed. If you are trying to reach a secure site, make sure your Security settings can support it. Click the Tools menu, and then click Internet Options. On the Advanced tab, scroll to the Security section and check settings for SSL 2.0, SSL 3.0, TLS 1.0, PCT 1.0. Click the Back button to try another link. Cannot find server or DNS Error Internet Explorer still don't work and refreshing dosen't work. |
04-19-2005, 02:25 AM | #59 |
And a bunch of dremelling later. (Sams going to kill me once the drugs wears off. He lost a lot down you know where) Looks like I need a new cage afterall. I moved the seats up quite a bit to make it look better. Now that I know what I am after I can make proper seat mounts. |
04-24-2005, 01:05 AM | #60 |
I got an email that there were problems bringing my domain name back up. Its been fixed and as soon as it propagates, everything should be fine... Heres a couple pictures of Sam after his foot surgery: (I know, I know, you can't see them yet!! ) Sam's done enough posing, and is itching to get back to the shop for more fabricating. |
