05-23-2007, 09:45 AM | #1 |
Newbie Join Date: Dec 2006 Location: vancouver, bc
| how to eliminate/decrease torque twist??
i have a tlt with custom chassis... specs WB - 12" GC - 3" width - 11" stock tlt shocks... do you guys have any preference on how to position the shock in order to reduce the torque twist?? |
05-23-2007, 10:57 AM | #2 |
2006 2.2 National Champ Join Date: Dec 2004 Location: Big Bear Lake
Can you post some pics of your rig? It'll be easier for people to help if they can see your set-up.
05-23-2007, 11:26 AM | #3 |
Rock Crawler Join Date: Dec 2005 Location: Mesa
Standing the shocks more vertical which will limit some of your articulation or run a stiffer spring on the one shock. Stock TLT shocks won't help you there assuming you're running a 4-link set up. Check this thread out. Way too much info. Anti Squat and Suspension Tech I'm glad I don't have to worry about all that on mine. |
05-25-2007, 10:16 AM | #4 |
Newbie Join Date: May 2007 Location: Canary Island
ok very nice
05-25-2007, 10:17 AM | #5 |
RCC Addict Join Date: Nov 2005 Location: Utah
turn your shocks upside down, make them not at a steep angle, run 80wt oil, most likely your custom chassis is most of it, play around with your links as well.
05-25-2007, 12:39 PM | #6 |
I wanna be Dave Join Date: Oct 2006 Location: Martinsburg WV
step 1 - ditch the stock TLT shocks they are too soft and no replacement springs are readily available. step 2 - read the thread Mriswith linked - it's full of valuable suspension setup info... |
05-25-2007, 07:03 PM | #7 |
thanks guys.... ill post some pix when i get home..
05-25-2007, 07:05 PM | #8 |
here is some pix that i have for now... i hope this will help... |
05-25-2007, 07:59 PM | #9 |
Your link set-up looks pretty good. I think upgrading the shocks and tuning them will cure your problem. The stock TLT shocks are too soft. You could stand them up more on the chassis to gain a little stiffer travel, but it will also limit flex.
05-25-2007, 08:16 PM | #10 |
I wanna be Dave Join Date: May 2006 Location: Arlington, VA
flip the rear axle upside down and fab a small gearbox on the rear trans output reversing the rotation from the front. this will counter act and cancel out the torque roll.
05-27-2007, 04:03 PM | #11 |
Quarry Creeper Join Date: Feb 2007 Location: Fresno
Thor, I like that idea. Now to find a machinist willing to try this little project.
05-27-2007, 04:12 PM | #12 |
yeah, seems kinda cool, in theory anyway. ive had an idea pop into my mind for an easy setup like that if i ever get a chance to further it from just an idea.
05-28-2007, 08:29 PM | #13 |
Rock Stacker Join Date: Apr 2007 Location: Philippines
Im still using the stock TLT shocks..The AE shocks I ordered hasn't arrive yet..what I did was to incease the preload on the rear shock that's experiencing the twist and added thicker oil...I used nylon zip ties as spacers. It help minimize the torque twist..
07-06-2007, 11:21 PM | #14 | |
I grabbed a pair of tranny top shafts at the LHS, now all I have to do is make a box for them, and rig it up. | |
