Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Heritage Crawlers > Tamiya TLT Crawlers
Thread: Project: TINY
Old 07-09-2007, 04:53 AM   #41
Talking
This thing is sick!
thanks for the pics
Shane
Rockmuncher is offline   Reply With Quote
Old 07-09-2007, 09:01 AM   #42
That thing should belong in the scale section, hopefully it will run as nice as it looks.
RedNeck Rc is offline   Reply With Quote
Old 07-09-2007, 09:07 AM   #43
06 Super National Champ
JasonInAugusta's Avatar
Nice work, Sam!
JasonInAugusta is offline   Reply With Quote
Old 07-09-2007, 09:22 AM   #44
I joined the Band!
wow....
xr100 is offline   Reply With Quote
Old 07-09-2007, 01:10 PM   #45
Originally Posted by smokinu_by_rc View Post
SAM thats crazy man you are making me want to build a tuber!!!
I must totally agree that one!
klrp is offline   Reply With Quote
Old 07-12-2007, 12:59 AM   #46
Well I got to touch the rig tonight. While the wife was away, I got to play (a little). So here are a couple additions to TINY.
I did some machining on one of the mating pieces for the rear offset axle. The upright in the photo will grab one of the links and you can see the axle tube pressed in place. It is a 1/4" diameter axle tube for visual reference.
This photo shows only one of the machined pieces in place. This poor diff donor was my original housing I had on my tuber years ago before it broke the ears off. I then was painted and bolted up to my Landrover's trailer with some Fat-Rock Cs on it. Now it will serve powered life again as my custom diff housing.
My next "cross my fingers and hope it works" is this new AAA battery pack. It's a 9cell 700 mah high drain pack from Cheap Battery Packs. I wanted the punch of more than what 7 cells could offer, so I bumped it up to a 9'er. Hopefully it can handle all the output it will see. Mostly I like it for the fact that I can lay it flat on the bottom of my chassis right in between the chassis rails and next to the driver seat. The driveshaft will route over the top of it. I am thinking I can swap it in and out from the passenger side.
First pic is of course the battery pack.
This horrible photo is of the battery within the rails.
Slowly slooooooooooooowly TINY will rise. The October Folsom event is getting too close for comfort now at this rate.
-Sam
SlinkySam is offline   Reply With Quote
Old 07-12-2007, 01:33 AM   #47
that custom axle looks amazing!
theshimonator is offline   Reply With Quote
Old 07-12-2007, 01:34 AM   #48
are you going to be at folsome sunday? ide like too see you again sam!
tiny is looking good were is the tranny gunna go if the batt sits right their?
smokinubyrc is offline   Reply With Quote
Old 07-12-2007, 08:18 AM   #49
Im Brandon
Brandon's Avatar
Great work Sam
Brandon is offline   Reply With Quote
Old 07-12-2007, 12:07 PM   #50
That battery pack looks neat! How you are going to do rear linkage, do you have pic of the other end of TINY's rear axle?
Old 07-12-2007, 06:29 PM   #51
I don't have an image of the other side of the axle, but just picture a circular colar going around the tube to support the wheel up against it as it rolls.
Thanks guys for the comments.
Smokin - I won't be at folsom unfortunately. I have a wedding to do. Gotta pay the bills. However, I should be at the October Folsom event and "should" have Tiny running for a little.......... SHAKE........... and BAKE!!. The tranny will actually sit partially under the bug motor and above the battery pack. Mostly there will only be clearance below the driveshaft which is where I am planning for the pack to be. We will see. I am designing things like an old western. Shoot from the hip style.
-Sam
Old 07-12-2007, 10:54 PM   #52
-Sam
nukin futs!
SHAKE 'N BAKE and get 'R done!
1600 posts TODD i am a post whore!!!!!
Old 07-13-2007, 12:33 AM   #53
Talking
Could you please post a couple of pics of the whole rear axle?
Shane
Old 07-14-2007, 01:16 AM   #54
Shane
I will post up some as soon as I finish the housing. Currently there isn't much to look at.
On another note, I fired up the 9cell AAA pack. WOW!!! I plugged it into my 55T Lathe and neck snap. It has the low end grunt to torque through a load (as far as carpet testing goes) and it has a huge punch to it. Now being that it is only 700mah, it most likely won't last very long. I noticed that the charge at .5 amps was quick. I can't wait to see what the run time really is.
-Sam
Old 07-14-2007, 07:30 AM   #55
Nor-CalRCRC
montereycrawler's Avatar
Sam, if you are still planning on running the rr2 motor I think you will be glad you went to 9cells. If you remember when I ran mine before that was on 8cells.
Rig looks great. Can't wait to see it in person.
montereycrawler is offline   Reply With Quote
Old 07-14-2007, 08:52 AM   #56
It was your experience that made me a bit nervous actually. I knew I had problems at 7 cells. I knew yours worked well with the setup at Indian rock but you still had some cogging. I actually thought you had 9 cells though, but now I am stoked to hear it was actually 8. So maybe there is a chance for good performance.
I look forward to running with you guys again.
-Sam
Old 07-14-2007, 09:34 AM   #57
Nor-CalRCRC
Yeah,,,, 9 woulda been better. I think my rig was about 5lbs. 2oz. at the time. I will say that the cogging was not as bad as some brushless i've seen since then though.
Old 07-28-2007, 01:06 AM   #58
Thought it was time for a little update. VERY little if we are being truly honest here.
So here is what I have done since last time:
- Rough machined up second axle bracket (1 to go)
- Threaded the rear axle shaft
- Test mounted links several times for preferred geometry (somewhat happy)
- Decided to rotate battery and bias it towards the front of the belly
- Mounted the tranny
That's it. See I told you not much was done. However, progress is progress even if a little at a time.
I took some setup shots just so you can see how things will roughly fit into place. I need to clean up the edges and finish of the rear axle, welds, and more. I also need to clearance one link to clear the diff housing. I wasn't planning on running it so close, but to get the link separation I needed, I will need to bend it a tad.
One thing I did notice when making vroom vroom sounds with it, I noticed that when I give the rear diff backward rotation as it would see during driving, the passenger side of the rig would torque down. This may be a bonus in countering standard torque twist as seen on standard 4 link rigs>
Here are the pics:
Here is TINY at what I might make it's normal ride height of ~ 2"s. The suspension can drop down to about 3.75"s.
There is 2.2" of clearance under the rear axle tube which is higher than the belly of the rig. That's pretty cool.
-Sam
Old 07-28-2007, 02:19 AM   #59
thats so fing sick!!!!!!!!
Old 07-28-2007, 02:22 AM   #60
Talking
Here are the pics:
Attachment 39325
Attachment 39326
Attachment 39327
Attachment 39328
Attachment 39329
Attachment 39330
-Sam
Looks great Sam
Very scale looking and also looks like it will do very well
Is the rod in the secod picture the back axle tube or the axle?
Shane
