10-29-2007, 09:09 PM | #81 |
2006 2.2 National Champ Join Date: Dec 2004 Location: Big Bear Lake
10-29-2007, 09:12 PM | #82 |
RCC Addict Join Date: Mar 2007 Location: des moines
Sweet thats always good to hear. I picked up a 50t "hard line" crawlmax from r2j. Is there a big difference in power or just a small one?
10-29-2007, 09:14 PM | #83 |
10-29-2007, 09:17 PM | #84 |
thats good..i will be using a 8t pinion and a 3s lipo to get the wheelspeed back..most of the shit you drive your truck out of i would pick mine up. Hows your cvds holding up the pin hole in mine is starting to hallow out
10-29-2007, 09:20 PM | #85 |
| My CVD's are holding up fine. I check the pins every couple packs to make sure they aren't sliding out.
10-29-2007, 09:25 PM | #86 |
the pins are have not moved thats what shocked me.one hole is slowly getting bigger.the season final comp is nov 18th..I will be using the 50t crawlmax and testing the kreepy tap.I need to find some better grease that lets the dig on the r2 slide alittle better any ideas anyones
10-29-2007, 09:28 PM | #87 |
graphite powder
10-29-2007, 09:41 PM | #88 |
and where could I get that? hey john what can I do about the drag brake on the quark been so strong? I have it all the way down and I still cant turn the wheels with my hand
10-29-2007, 09:46 PM | #89 |
graphite can be found anywhere, a hardware store around the locks or lubricants. You might have to change modes on the Quark. Have you tried 3% drag to see if it reduces? |
10-29-2007, 10:02 PM | #90 |
yeah I have didnt seem much less..thanks ill pick some up
10-29-2007, 10:31 PM | #91 |
MWRCA'er Join Date: Apr 2004 Location: Machesney Park IL
If you don't find some I could probably hook you up at the comp. Teflon Dry lube also works good.
10-29-2007, 10:35 PM | #92 |
thanks i'll let you know
10-30-2007, 03:49 AM | #93 |
So if your going brushed, are you going to a mamba max? Just wondering about the drag brake strength. I know it's on the weak side as far as holding power with brushed motors. Next year, all catch you in scores, next year... |
10-30-2007, 09:06 PM | #94 |
my rig is very light and the drag brake is to strong im hoping with a brushed motor and the max's I can get the drag brake the way i really want it also I want more wheel speed and low in. as far as next year goes we will see
10-30-2007, 09:48 PM | #95 |
What gearing and voltage are you running?
10-30-2007, 10:07 PM | #96 |
3c lipo and 12t pinion on the 850kv c/m
10-30-2007, 10:17 PM | #97 |
The brushed motors should be fun on 3s lipo too. The drag brake difference is noticable though.
10-30-2007, 10:21 PM | #98 |
Run stiffer brush springs on your motor, or stiffen up the stock springs by winding them tighter, it'll make a huge difference in the amount of drag brake you can get with a Mamba Max and a brushed motor. ;)
11-07-2007, 07:01 PM | #99 |
I have found the drag brake with a brushed motor alot more to my likings the brushless motors have alot of holding power..im running 10% drag brake with the crawlmax and it is just right for me I my even set it down to 5%.I like for my rig to slow roll but not come to a full stop.anyway it has been to clod the last couple of day to crawl much so I have been working on a new link setup and massing with the brushed motors I will soon be going back to brushless motors when i find a way to lessin the drag brake. lmk what you think |
11-07-2007, 07:15 PM | #100 |
Run zero drag on the brushless, that would make just the magnetic cogging give you drag. I like a lot of drag on my super, but very little on my 2.2. Just enough to keep it from accelerating down a steep incline.
