11-07-2007, 07:28 PM | #101 |
RCC Addict Join Date: Mar 2007 Location: des moines
i have tryed that still to much for me..the quarks with c/m's and 6t pinions have more holding power a 3% then the max's did with the c/m's 6t pinions at 100% does the cheap esc have less drag brake then the quark? I ran a 14t pinion and still had to much drag brake even with the drag brake turned off and the revoler black :-(
11-08-2007, 04:48 PM | #102 |
well I tested the new link setup today I love it.flexs real smooth now I stripped a rcp pinion the ring gear is still fine comps next weekend im not sure if im not to use stock gears or rcp gears
12-16-2007, 11:10 AM | #103 |
well Im bored so here are some pics I took.today |
12-16-2007, 12:12 PM | #104 |
Looks good Lee. I like pretty purple shocks, did Ricki pick those out for you! |
12-16-2007, 12:24 PM | #105 |
no the bule was out of stock and i need shocks to come down there and kick your ass like I did after that I said to hell with it and kept them. but really the hot bodies shocks are very smooth |
12-16-2007, 12:30 PM | #106 | |
To bad you wasted your one good run on a week when I was having issues, your going to need it next year! | |
12-16-2007, 12:51 PM | #107 |
| it seems like every comp Im with you something of your brakes..I swear I didnt rig your trucks yet anyways jk man I hope you new rig works better for ya..I just hope I can stay as comsistant so I have been
12-16-2007, 01:01 PM | #108 |
| Yeah, the Grunt was reliable as hell for over a year and then I started puking servos and I had that weird stall issue? I'm starting to think your bad luck Lee!:-P
12-16-2007, 01:03 PM | #109 |
maybe I am maybe i am but it works out in my favar so I dont mind |
12-16-2007, 04:45 PM | #110 |
Hey Lee, Good to see you post.. Happy Holidays to you and Rikki....Storm
01-25-2008, 10:08 PM | #111 |
I ordered a 7t puller motor,cc bec and a new body Im going with a new pain skeam Ill post pics as soon as I get time to get the body done
01-26-2008, 04:34 PM | #112 |
Yup post the new 2008 rig up Lee, will you and Rikki be crawling with the Minnesota gang again this year?
01-30-2008, 06:29 PM | #113 |
here the body I painted Im still waint on my other parts |
02-06-2008, 05:02 PM | #114 |
got my puller mounted and bec hooked up.I took the truck for a test drive to day..holy shit those puller have some wheel speed and alot more power then what Im use to. |
02-06-2008, 05:10 PM | #115 |
Tight fit... Glad it all arrived safe! Sounds like you will enjoy the motor, practice jumping off of objects with it. I can fall off about anything with mine and land on all 4 tires now. We are gonna have identical rigs it looks like |
02-06-2008, 06:17 PM | #116 |
the motor is by far the best motor I have ever drove..sweet I cant wait to come down and crawl with you guys again.you'll like the sw3 will you be running the r2d or just a r2?
02-20-2008, 07:26 PM | #117 |
Rock Stacker Join Date: Jul 2006 Location: all over
nice rig. great job
02-20-2008, 07:29 PM | #118 |
02-20-2008, 07:46 PM | #119 |
Rock Crawler Join Date: Apr 2006 Location: Eau Claire
Sweet rig Lee! Hope to get a look at it in person in TF this spring! |
02-22-2008, 05:44 PM | #120 |
After going through about six sets of stampede driveshafts i upgraded to max driveshafts and thats when i started breaking rcp pinions. So i ordered some stock pinions to get me by while my rc4wd steel one got here. Today i got my truck all back together decided to test it out on the carpet, withing 5 min of driving it i popped the max drive shaft off. Should i upgrade to steel driveshafts or should i leave my driveshafts plastic to help keep down on the cost of broken axle parts? Is there anyway to keep the max yokes from popping apart? Found out tonight i need a lot bigger than an 8 c to use with the puller. My lipo go to about 100 degrees |
