08-11-2007, 04:22 PM | #1 |
Rock Stacker Join Date: Jul 2007 Location: Oakhurst
| Whats the deal????
I have a tlt with 4 wheel steering and a TQ3 radio system (the one you can buy from tcscrawlers with the rear steer mod) The servos im running are two 645 mg hitec servos. when i approach an incline enough to were it is almost flexed all the way, the radio system "stalls" and i get no feedback or no control and the wheels just twitch back and forth, i have to pick it up and move it for it to go back to normal. Idk whats wrong with it ANY advice is always appreciated. Nate
08-11-2007, 04:26 PM | #2 |
R.I.P. Chip Join Date: Jan 2004 Location: The Crawler State
Your 2 steering servos are pulling more power than the BEC in the ESC can handle and it is shutting down.
08-11-2007, 05:23 PM | #3 |
Rock Stacker Join Date: Feb 2007 Location: Cincinnati
Yep, you're tripping the BEC. You can either get an ESC with a higher BEC (like a rooster crawler with it's 5A BEC) or you can get an external switching regulator and wire it in line.
08-11-2007, 11:02 PM | #4 |
RCC Addict Join Date: Aug 2005 Location: Pocatello
What ESC are you running? You can also run a RX pack with it.
08-11-2007, 11:04 PM | #5 |
Pebble Pounder Join Date: May 2005 Location: raleigh
if you dont have money to buy a new esc i would just go with a rx pack their cheap and will stop that problem completly!
08-12-2007, 12:31 AM | #6 |
I wanna be Dave Join Date: Jun 2005 Location: KENNEWICK, WA
This is your solution right here...... Castle BEC on Sale! ** BACK IN STOCK ** |
08-12-2007, 02:40 AM | #7 | |
Rock Crawler Join Date: Mar 2007 Location: Colorado
08-12-2007, 08:33 AM | #8 |
Pebble Pounder Join Date: May 2007 Location: United Kingdom, wales
hi yea i had the same problem but on clod axles with two servos using to much power and tripping the BEC and i have added and rx pack to the reciver and it has solved my problem and the rx pack only caot me about £10 but would be cheaper in the US
08-12-2007, 11:07 AM | #9 |
thanks for all your help i guess i should get a better esc since all im running now is one of those cheap 50 dollar duratrax ones. i think i will go with the TR2 seems like a good value but tcs says i would have to run a voltage regulator if you run ultra high torque servos. should i buy the regulator 2?
08-12-2007, 11:51 AM | #10 |
Rock Crawler Join Date: Jan 2006 Location: Connecticut
Ive heard alot of problems with the TR2. You would be better going with the new Novak Rooster. One of the guys I crawl with has one and its sick!! Very nice. You might need a regulator, you might not. Ive ran two Hitec 5995TG's w/ dual 55 turns on one Super Rooster with no problems. Did the same with a Mamba Max also. Id go with the new Rooster if I was you. Price wise I beleive it is the same as the TR2. |
08-12-2007, 11:56 AM | #11 |
One other thing to consider, is how many cells you run. The more cells(higher voltage) the less amps the BEC can put out.
08-12-2007, 02:42 PM | #12 |
i run a 3300 mah battery stick
08-13-2007, 11:46 AM | #13 | |
Rock Crawler Join Date: Apr 2006 Location: pasco,Wa
08-13-2007, 02:58 PM | #14 |
I just ran the Rooster Crawler in my Super at the comp yesterday. I was running a J9000T in front (200 in/oz) and a 645MG in the rear, off of the BEC. Not a single problem. Last edited by Grizzly4x4; 08-13-2007 at 04:04 PM. |
08-13-2007, 03:30 PM | #15 |
Quarry Creeper Join Date: Jul 2007 Location: Racking my Brain
the rooster(crawler model) is awsome but if you dont want to dish out the money for a new speedcontrol the castle BEC is the way to go it cost only a little more than a good reciever pack and charger and you dont have to worry about charging an extra battery
