![]() | #101 |
Rock Crawler Join Date: Mar 2004 Location: Where it's wet
![]() | #102 |
Pebble Pounder Join Date: Jun 2006 Location: GreenWood lake
Thats one nice rig you have there
![]() | #103 |
Rock Crawler Join Date: Jan 2005 Location: Tumwater
DOH...can I drive that at the nationals? J/K I cant belive you let this truck OUT before the biggest comp yet! It gets my vote as the coolest comp rig ever. Chad- |
![]() | #104 |
owner, Holmes Hobbies LLC ![]() Join Date: Nov 2004 Location: Volt up! Gear down!
he just wants to rattle everybody he is going up against. I am keeping mine under wraps till Nationals.
![]() | #105 | ||
Quarry Creeper ![]() Join Date: Mar 2005 Location: The Dark Side
| ![]() Quote:
I guess it would have been smarter to post after the Nationals but I new this would be more fun !!! Here's to Getting Rattled !!! | ||
![]() | #106 | |
| ![]() Quote:
Chad- | |
![]() | #107 |
The chassis is working out GREAT !!! I built it with a 12" wheelbase, that's 1/2" shorter than before, to help shorten the turning radius. It's just too short on the vertical climbs and doesn't hold the front down. I had some scap carbon fiber kicking around and decided to fab up some sexy new chassis plates with the rear plate being 1/4" longer. ![]() I also removed some excess weight from the plate mounts while they were off. I saved 3 grams with the longer carbon chassis plates, and 2 grams from each plate mount. Not only do they look cooler but what a difference on the rocks !!! |
![]() | #108 |
Brilliant! ![]() I only wish I had half of your fabbing skills. If you ever decide to market that crawler, I see the TVP chassis going the way of the dinosaur! |
![]() | #109 |
I'm really happy with the HPI Baja Bug body I've been running for the last year but it seems to on every other 2.2 I see. I saw someone at Nationals running a buggy body and I got to thinking... ![]() ![]() It's from a Losi XX buggy. I used about a 110 % of the body. I dig the moon buggy look it gives Buster. |
![]() | #110 |
Rock Crawler Join Date: Jan 2006 Location: In the basement
Thats what I call "thinking outside the box"
![]() | #111 |
I know everyone is going brushless, my Unlimited Clod is going to make the switch soon, but I have no major problems with a lathe motor in my 2.2 . I just don't like those 80's tech cans and endbells they come with. While checking out a new crawl spot, I stopped at the LHS and scored a nice used mod motor. These Swiss made V-style motors are TOP cans like most lathe motors so endbells and cans are interchangable. I swapped out the old 13x2 armature for a new 55x1 lathe and installed new brushes and soft springs. Built-in capacitors, BIG brushes, a LED when it's running, and it LOOKS HOT while it runs cool. ![]() |
![]() | #112 |
That's pretty cool, we used to buy the rebuild-able aluminum end bell Mod motors and install a 540 armature in it for the endurance races at SRS raceway in Tucson or Tempe, don't remember which one it was. ![]() I might try that for my Clod as I still use lathe motors in it! ![]() |
![]() | #113 |
I got this one for $25.00 @ SSR. The manager said he get's them all the time for $20.00-30.00 each, bushes and springs ran me $4.00/pair.
![]() | #114 |
Was it a particular brand? Trinity, epic, ect....?
![]() | #115 | |
| ![]() Quote:
![]() | #116 |
Dirt Addict ![]() Join Date: Jan 2004 Location: Stumblin' thru the parking lot of an invisible 7-Eleven
Nice.....your stuff always looks so bling. Jay |
![]() | #117 |
Rock Crawler Join Date: Jan 2006 Location: Connecticut
Nice job!
![]() | #118 |
Well I finally decided to jump on the brushless-bandwagon. The light weight and drag brake are proving to be too great of an advantage to pass on any longer. I found a sweet little brushless from GWS for their Slow Stick parkflyer. It retails for around $20.00-25.00, it's 1.8oz and 1020kv, perfect for a TLT. One problem though, it ate my transmission something a lathe motor never did. So in order to run the brushless I had to make a new tranny. The new AE RC10GT2 had a 4.09:1 trans, the perfect gear set for a crawler tranny. ![]() ![]() ![]() |
![]() | #119 |
Rock Crawler Join Date: Feb 2007 Location: CoMo...Kickin it with Holmes Hobbies
wow this is truly impressive, three tranny overhauls, you really know your stuff
![]() | #120 |
Newbie Join Date: Feb 2007 Location: Tigard
What shocks were you running that had the resevoirs? Thanks |
