01-10-2008, 01:14 PM | #261 |
2006 2.2 National Champ Join Date: Dec 2004 Location: Big Bear Lake
01-10-2008, 07:03 PM | #262 |
I have been debating putting the links on the inside, but I haven't really gotten hung up where they are yet, so I haven't done it. But I like how yours looks with them inside. Swiss cheese........mmmmmmmm |
01-10-2008, 07:18 PM | #263 |
Pebble Pounder Join Date: Sep 2007 Location: Not where i should be
Brad, The new skids look good, looking forward to mine;) I'm running my lower links inside the chassis, trianglulated as well with AX10 axles. Due to the width of your chassis and a few mods to the front axle, turning circle is heaps better than stock. |
01-10-2008, 07:23 PM | #264 | |
Your skid is in the mail. | |
01-10-2008, 07:28 PM | #265 |
[HOONIGAN] Join Date: Nov 2005 Location: Grand Junction
01-10-2008, 07:31 PM | #266 |
01-10-2008, 07:34 PM | #267 |
| I basically have a plastic on plastic "drag brake", The o-rings just helps absord the load and space everything out to where I need it to be. The brake puts a little resistance on the rear wheels, but it won't turn as tight as a rig that can dig with the rear wheels locked.
01-10-2008, 08:05 PM | #268 | |
01-10-2008, 08:20 PM | #269 | |
I wanna be Dave Join Date: Jul 2006 Location: Elberfeld
I've since remedied this problem. I'll be posting a rebuild thread of my SW3 soon. | |
01-12-2008, 09:48 PM | #270 | |
Quarry Creeper Join Date: Aug 2004
was just a bad day, but I felt better when I got the little somethin somethin in the mail! Thanks and thanks for the custom order one as well. -peter- | |
01-12-2008, 09:54 PM | #271 |
| No problem Peter. Sorry to hear the comp didn't go your way, we've all been there at one time or another. |
01-12-2008, 10:45 PM | #272 | |
I rushed the first course, was too cautious(sp) on course 2 and I blew a my front ring and pinion on 3 but I drove it liek I stole it for 3 progress ponts! hehehe -peter- | |
01-14-2008, 12:12 PM | #273 |
Pebble Pounder Join Date: Jun 2007 Location: Tyler, Texas
| AX10 Tranny
Hey Brad, I added the scorpion tranny to my SW3 about a month ago and and pretty much mounted it up the same way as you. Looks great by the way. When I got ready to mount up the max shafts I realized how short and tiny the output shafts were and didn't want to drill them to make things worse so I ordered some of those RC4WD aluminum output shaft adapters, the 5 to 6mm I think. They slip over the scorpion output shafts perfectly and attach with a 1.5 set screw. They've held up great with no problems or clearance issues. I didn't have to shave the max yokes near as much either. I just thought I'd make a suggestion that worked for me. Here's a link to the adapters: http://rc4wdstore.com/product_info.p...roducts_id=557 |
01-14-2008, 12:15 PM | #274 | |
I was just looking at your build, I like how you bent the sides of the chassis in. | |
01-24-2008, 11:41 AM | #275 |
Pebble Pounder Join Date: Mar 2005 Location: England
Hi Just wondering how you mated the MSD beadlocks to the tlt CVD'S ? Did you drill out the centre hole to 7mm or something else heavyD |
01-24-2008, 11:44 AM | #276 |
01-24-2008, 11:53 AM | #277 |
Thank you Bender for your fast reply much appreciated heavyD |
01-29-2008, 03:55 PM | #278 |
Rock Crawler Join Date: May 2007 Location: Glendora
01-29-2008, 04:05 PM | #279 |
Powered by Awesome Join Date: Sep 2004 Location: Parker, Colorado
01-30-2008, 03:54 PM | #280 |
So it is safe to assume that the CVDs will poke through the rims once it is drilled out? Then washers will be needed to take up the slack between the wheel nut and the rim? I do not have these in my hand yet, but I am trying to get an undrstanding why they will not work straight from MSD without MODS?????? |
