Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Heritage Crawlers > Tamiya TLT Crawlers
Thread: My latest SW3 build........Good-bye Bug, Hello Grappler
Old 01-30-2008, 05:00 PM   #281
Keep it real
Tanis's Avatar
The CVD's come with the appropriate spacer to take up the slack, and the MSD's are made with stock axles in mind, and it's not a big deal to drill out the hole a little
Tanis is offline   Reply With Quote
Old 01-30-2008, 06:01 PM   #282
What kind of drill bit (and size) would you recommend? I ask, because I am not a machinist and I do not want to F@*K up these GREAT rims from MSD!!!!!!
difflocker is offline   Reply With Quote
Old 02-09-2008, 12:45 AM   #283
In your shaggin wagon build thread you mentioned running the additional screws for the servo mount was not necessary
which was correct
but recently the 2 screw that go through the mount and screw into the axle have been backing out.
which causes the plate to move around
would one solution be to put 2 additional screws to hold the plate
or
buy another axle case?
thank you for your great customer service
ps your inbox is full
iwantoffroad is offline   Reply With Quote
Old 02-09-2008, 12:54 AM   #284
which was correct
or
I use the BENDER upper link mounts also . they are great mounts but the Axle Case hole are weak . this is what I done to mine . upper link mount mod
Badd is offline   Reply With Quote
Old 02-24-2008, 11:33 PM   #285
2006 2.2 National Champ
BENDER's Avatar
or
I'd use all 4 screws if possible. Try a few drops of CA in the axles cases you have now, and run the screws back in. It should help fix the stripped threads. If that doesn't work, a new case should fix the problem.
I used a 1/4" drill bit on the center of my MSD wheels. I used an 1/8" drill bit for the breather holes, 1 per wheel.
I got a new Grappler body painted up for the Mid-West Comp next weekend. I'll also be swapping out to a new set of Rock Claws, probably while we're on the road.
BENDER is offline   Reply With Quote
Old 02-25-2008, 01:00 AM   #286
STEW<CO>'s Avatar
Looking Good Bender, I like the clear windows instead of blacked out. If you need someone to train with this week, my schedule is open, let me know.
STEW<CO> is offline   Reply With Quote
Old 02-25-2008, 01:13 AM   #287
R.I.P. Chip
jason's Avatar
I am planning on running a bunch this week up at the thornton location;)
jason is offline   Reply With Quote
Old 02-25-2008, 08:28 AM   #288
BENDER's Avatar
Thanks man.
I'll be working a swing shift this week, so I'm not sure I'll have much time to practice before we leave.
Old 02-25-2008, 11:23 AM   #289
New body looks good, can't wait to see some Mid-West Comp pics.
LIKES2CRAWL is offline   Reply With Quote
Old 02-25-2008, 05:39 PM   #290
Keep it real
Tanis's Avatar
New lid looks sweet, have fun at the comp
Old 02-25-2008, 06:17 PM   #291
Location: Taylors Falls just hanging with the MNRCRC crew.
Good looking rig Brad Now go get em at the comp.
Stormin2u is offline   Reply With Quote
Old 02-25-2008, 06:27 PM   #292
666
MODERHATER™
666's Avatar
Where do I get one of those CO stickers?
666 is offline   Reply With Quote
Old 02-25-2008, 08:57 PM   #293
BENDER's Avatar
Rubbanecka.
Thanks for the compliments guys. I got my new MSD lockouts for the rear axle installed too. I'll post some pics in a bit.
Old 03-09-2008, 12:42 AM   #294
BENDER's Avatar
I finally got the MSD lockouts installed in the rear. Very well thought out design, rounded on the bottom and flat on top. The top of them would be perfect for extra stick on weights, if needed. They bolt right up with ease too.
Old 03-09-2008, 12:56 AM   #295
Keep it real
Tanis's Avatar
Those are nice
Old 03-09-2008, 12:58 AM   #296
BENDER's Avatar
Thanks Nathan, the lockouts are very slick.
I stripped the M3 threads for the kingpin screws in my modded RC4WD knuckles, so I drilled and tapped them for 6-32 socket head screws. Then I had to drill the kingpin holes in my original C's out to fit the heads of the 6-32 screws. Over time the arm on one of the knuckles has started to bend slightly, you can see it a little in the pics. So, it's time for an upgrade to the MSD axle C's and RCP's aluminum knuckles. I threw them together to see how the steering felt, it's very smooth with very little slop. The machine work on both these products is top notch.
I'll try and get them installed tomorrow, and maybe get a little testing in.
Old 03-09-2008, 03:21 AM   #297
They do work nice for stick on weight . look in this pic you can see I have some weight on them .
Old 03-10-2008, 11:51 PM   #298
I like the MSD C as well, but had to really open up the cut out for the steering knuckle to max steer. Not a big issue, but I would check the fit of your alloy knuckles.
nice pics.
-peter-
ronbeck is offline   Reply With Quote
Old 03-11-2008, 01:55 AM   #299
BENDER's Avatar
Originally Posted by Badd View Post
They do work nice for stick on weight . look in this pic you can see I have some weight on them.
Very nice, your rig looks sick.
nice pics.
-peter-
Yeah, I noticed that too, no biggie. At least the knuckles have a beefy arm.
