10-03-2007, 04:56 PM | #21 | |
2006 2.2 National Champ Join Date: Dec 2004 Location: Big Bear Lake
I did have to machine the knuckles to work with these axle C's. | |
10-03-2007, 05:00 PM | #22 |
Ah, I see. I will try to adjust my knuckles to work, as these C's are nice, and such a waste to just sit in the toolbox. |
10-03-2007, 06:14 PM | #23 |
Pebble Pounder Join Date: Apr 2007 Location: parked in a handicap spot
hey bender.. how much clearance do you have under the skid and what is the length of your shocks fully extended and what oil are you running.?. i wanna do a setup on my sw3 where the stance is sitting low but where it still get full suspension travel with out having to go with a droop setup if you know what i mean? also on the sw3 which do you like better 50/50 or 60/40?
10-03-2007, 06:19 PM | #24 | |
10-03-2007, 06:29 PM | #25 |
Rock Crawler Join Date: Mar 2007 Location: Man Cave!
Hey Brad, glad to hear your going to ditch the tamiya plugs I think brushless is fadeing a bit now, I know I have wanted it out since the comp before last in my 2.2. Except for the new crawlmaster system by Novak I think the brushed motors are better, I just can't find a 45t integy any where. Your ride always impresses me with it's simplicity, just goes to show, the driver is most important. Looks like I'm poop out a luck! Nice of you to do a write up and photo shoot for everyone, always willing to help, that's what makes you da man. |
10-03-2007, 07:42 PM | #26 | |
[HOONIGAN] Join Date: Nov 2005 Location: Grand Junction
The rig looks great Brad. Thanks to you I now have a mamba max in the mail and a brushed motor. It will be sooo nice to have the low end throttle control back and no reverse delay. Quote:
10-03-2007, 07:57 PM | #27 | |
Rock Crawler Join Date: May 2007 Location: Glendora
I just recently got a set of TLT axles from Kaetwo with those C's and the rear lockouts. THEY ARE BEEFY!!! Have you run into and problems with "slop" on the C's? Quote:
10-03-2007, 07:58 PM | #28 | |
10-03-2007, 08:00 PM | #29 |
By the way....your SW3 chassis is awsome! I appreciate the CRAFTSMANSHIP!!!!! THe whole package is sooo fluid over the rocks. |
10-03-2007, 08:10 PM | #30 | ||
Thanks for the compliments on the chassis too. | ||
10-03-2007, 08:12 PM | #31 | |
Yup, I run cvd's in the front. One thing to note, if you run cvd's with these c's or lockouts you might have to space them out. The king pin hole is about 1mm to far out, so with cvd's they will bind really bad. To fix this I had to take all the e-clips off of the axles and place a traxxas teflon washer on each side of the diff and a standard metal washer (one that fits over the cvd stub) behind the cross pin for the hex. This pulls the cvd out about 1mm lining it up properly with the c so you have no more binding. I've been running this for several months now and have not had any problems not running any of the e-clips or having th axle pulled out slightly. The same thing goes for the rear straight axle adapters. Sorry for polluting your thread Brad. | |
10-03-2007, 08:16 PM | #32 | |
10-03-2007, 08:26 PM | #33 |
RCC Addict Join Date: Mar 2007 Location: des moines
have you seen a great performance gain with the new suspension mods?
10-03-2007, 08:31 PM | #34 |
10-03-2007, 08:44 PM | #35 |
I wanna be Dave Join Date: Dec 2006 Location: In Cali.
10-03-2007, 08:48 PM | #36 |
10-03-2007, 08:50 PM | #37 |
by partial droop do you mean shorter springs and no internal springs?
10-03-2007, 09:03 PM | #38 | |
Not that I've noticed, but more testing will tell for sure. Correct. I basically backed my preload spacers way off, so the shocks now sit half compressed under the weight of the rig. | |
10-03-2007, 09:19 PM | #39 | |
I wanna be Dave Join Date: Mar 2005 Location: Hiding from Goodall
Do you want to borrow a quark33 and revolver black for a while? I am going to play with a mamba max in mine to see how it stacks up. | |
10-03-2007, 09:22 PM | #40 | |
I have a black revolver here, I may give that Quark a try at some point. | |
