11-16-2007, 08:58 AM | #1 |
varcor.org Join Date: Aug 2005 Location: 757
| Project Rock Surfn - another tuber - Updated
Well it's time to start another project. My 2.2 comp rig is torn apart at the moment. I'll be using the chassis for my TXT building up. So I had my tuber chassis that I got from Wrecker (thanks again!) and it was time to start building it up. So far, I have the tuber setup as a roller. I haven't decided on what trans to use, my R2 or my pede. But I know I will run brush less in this setup. And yes, I know it sits high but there's no electronics and still tweaking the shocks. In this setup, its setup 30% droop/70% sprung with 80wt oil. Here some quick specs: WB: +/112", W: -10", H: 7" (w/o electronics). And the chassis is within comp specs - L: 8.5", W: 4.5", H: 4". Here are some pics: Things to do: 1) mount trans, motor, and electronics 2) tweak the links and shocks 3) narrow the pede wheels or run Axial beadlocks 4) find a battery setup 5) find some ROCKS for it's maiden voyage!!! Last edited by swell searcher; 12-11-2007 at 09:29 PM. |
11-16-2007, 09:03 AM | #2 |
Rock Stacker Join Date: Nov 2007 Location: Clifton, VA
Wow, awesome! |
11-16-2007, 12:29 PM | #3 |
Quarry Creeper Join Date: Jul 2007 Location: Holland,OH
Looks great, luv the flames!! If I might ask, what are those brakets from that your upper links bolt up to? I've been tryin to find some for mine. Thanks, Chris
11-16-2007, 12:40 PM | #4 |
[HOONIGAN] Join Date: Nov 2005 Location: Grand Junction
SWEET! I've been waiting to see this thig get built up! I'm glad you like it. I would bump the wb out to 12.5" though. It will drop the chassis down quite a bit and perform much better with the lower cog and climb alot better. Looks like a great start though. If you do want to keep the wb on the short side though, using some shorter shocks or going to a full droop setup would help get the stance and geometry were it should be. |
11-16-2007, 12:47 PM | #5 | |
those brackets came with my J2-TT chassis. You can buy them from TCS (Reign's servo plates) or RCP Crawlers (RCP plates or RCP plates w/ link mounts), or you can make your own from angle iron. | |
11-16-2007, 12:52 PM | #6 |
| thanks wrecker. awesome chassis. i got the shorter WB because i was lazy about cutting my own links last night (lowes has some 3" 8/32 all-thread). but i think i'm going to full droop on this one. if she doesn't climb well, then i'll push the rear out another 1/2".
11-16-2007, 12:53 PM | #7 |
Pebble Pounder Join Date: May 2007 Location: "In a van, down by the river!"
| Nice buggie!
I love it...especially the rims & tires. It was the very first set-up I put on my very first crawler. See: |
11-17-2007, 12:35 AM | #8 |
Thanks for the links. just what I was lookin for.
11-19-2007, 07:00 AM | #9 |
I got the electronics mounted. I went with my Hacker BL motor, Mamba esc, and Hitec 645 servo. I also changed to a full droop setup and narrowed the pede wheels slightly. I finished this all Saturday night. :-P I met up with Baldchris for her maidan voyage. She ran well with the 9.6v 2/3a battery setup and the 7.2v sub-c setup. I think I'm going with the 2/3a setup. With the droop setup, she side hilled and climbed well. I definitely like the LCOG. I need to recut the foam, damn glue. In the end, I broke the driver rear shock mount and lost my pinion gear. The pinion gear is an easy fix. I need to tweak the motor mount some since it worked itself loose. The shock mount... hmmm... i suck at brazing and the chassis was cleanly done. (Maybe time to start the TXT build...) The only pics I have are the aftermath... Last edited by swell searcher; 11-19-2007 at 07:11 AM. |
11-19-2007, 07:38 AM | #10 |
Newbie Join Date: Sep 2007 Location: portland
you have a really good looking tuber. i like the look of the droop. sorry that it broke. i was wondering how you bent and cut the lower plate?
11-19-2007, 08:03 AM | #11 |
i got the chassis from wrecker but it aluminum and more than likely bent in a vise.
11-19-2007, 01:32 PM | #12 |
| I cut it with a 4.5" angle grinder with a cut-off wheel, super fast and it's really easy to get a perfectly straight line compared with using a dremel. To bend it I just clamped it to the edge of my work bench (with a sharp edge, 1/2" mdf board) and then bent it by hand. It works really good and you can get a perfect bend if you take your time. |
11-19-2007, 04:30 PM | #13 |
Thanks for the the help.
11-19-2007, 10:06 PM | #14 |
Quarry Creeper Join Date: Sep 2005 Location: on the rocks
Looks good bro BTW the pink flames will match the barbie Jeep you wheel |
11-20-2007, 05:52 AM | #15 |
11-20-2007, 05:50 PM | #16 |
11-20-2007, 06:45 PM | #17 |
11-27-2007, 10:06 PM | #18 |
| excited!!!
wrecker kicks ass!!! he redid the shock mounts for me and here's one of the teaser shots he sent me: i'll post some action shots as soon as i get her rebuilt!!! Last edited by swell searcher; 11-27-2007 at 10:20 PM. |
11-27-2007, 10:38 PM | #19 | |
This new setup should work alot better with your setup. Be sure to post pics of it built back up, and some video too. | |
11-27-2007, 10:45 PM | #20 |
