Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Tamiya TLT Crawlers
Thread: new chassis for tlt crawler
Old 07-06-2004, 07:02 PM   #1
Default new chassis for tlt crawler
i went to the store today and was looking around and found some plxiglass. and thought about building a chassis cause i was just going to take the old chassis and cut it all up. but that would be a little hard. so i am going to make a chassis out of the plexi-glass. i will have a layout by friday i just have to look at the truck and start drawling. and i think that a clear chassis will look sweet.
tltcrawl is offline   Reply With Quote
Old 07-06-2004, 07:41 PM   #2
Default Re: new chassis for tlt crawler
what do you guys think?
Old 07-06-2004, 09:10 PM   #3
i started to make mine out of that its a pain in the @$$ cause it cracks and stuff but idk what i used what a protractor lol it worked great lol but i cracked it so it went in the garbage but goodluck
firstumustcrawl is offline   Reply With Quote
Old 07-06-2004, 09:16 PM   #4
thanks man i hope that minie does not crak if it does i will just make a new one. i am going to be crawling and not flyin down the road so it should be fine i think.
Old 07-07-2004, 07:06 AM   #5
TCS Team Manager
Fishmaxx's Avatar
Use Lexan it dosn't crack like plexi
Fishmaxx is online now   Reply With Quote
Old 07-07-2004, 09:10 AM   #6
binaryterror's Avatar
I'd use G-10 Fiberglass...cheaper than CF yet nearly as strong.
Go to www.mcmaster.com and search for G-10. For the TLT you probably only need 1/16" or 1/8" sheets
binaryterror is online now   Reply With Quote
Old 07-07-2004, 10:00 PM   #7
Yea plexi is hard to work with. I experimented with it in my sound system but got frustrated. Lexan is better. With so many different materials available why do u wanna use plexi. Just for that clear see through look? Would look sweet though!
cman_1500w is offline   Reply With Quote
Old 07-07-2004, 10:51 PM   #8
well i was at lowes and saw it so i was like humm. so i picked up a few sheets and i am going to see what i can do. i have a dremel so i think i can do anything with that. it just takes time. and time i have, i bought a tlt off of ebay and it has been 8 days and i still have not gotten it so maybe i will tomm. so i can wait. but i just want to try it.
Old 07-07-2004, 11:32 PM   #9
yeh i was trying it for my real car too like cman i used it for stereo but i just ended up buying clear red lexan and looks way better much easyier to work with
Old 07-15-2004, 03:14 PM   #10
the dremel wont work very good. it melts it and makes purple globs of melted plexi all over your work. the globs can be broken off but it takes forever. i would just go with lexan it will be stronger, more resistant to cracking, and will be alot easier to work will. The only downside i can think of is it may cost more than plexi but you wont need much and it aint that bad. Cool idea though. If you want to go threw the pains of using plexi go for it. You can make the plexi work its just real hard and takes patience. Post pics when your done.
pedesrule is offline   Reply With Quote
