06-07-2005, 01:04 PM | #21 |
Quarry Creeper Join Date: Jun 2005 Location: quarryville
i meant what parts are stock tlt parts and what parts are stock bruiser and whats after market on the truck
06-07-2005, 03:13 PM | #22 | |
Web Wheeling Join Date: Jan 2005 Location: Twin Cities
TLT axles Stampede tranny Stampede drive shafts Bruiser frame rails Custom aluminum cross members and tranny mounts Custom aluminum shock mounts, fronts need to be redone. They are just mock up towers. TLT shocks HPI rims HPI Geolander tires Bruiser front cab piece Associated BFT links and lots of other custom parts. So in the end, not much TLT left, and not much Bruiser. But without the TLT and bruiser parts, this truck would be nothing but a box of parts. | |
06-07-2005, 03:16 PM | #23 |
Quarry Creeper Join Date: Apr 2004
The framerails are from the bruiser, thats it. The axles and shocks are TLT, the tranny and driveshafts are stampede. Other than that, it is all custom made. I'm glad you did this Etype, as I have a pair of bruiser framerails sitting around and I was getting lost as to what to do for a chassis for my TLT axles, so I'm thinking of using your truck as a reference if that's ok with you. I may get a clod body for mine, bob the bed, hmmm the ideas Great truck though, I've been watching the buildup over on scale4x4 and to see it finally close to done its just awesome!
06-23-2005, 10:42 AM | #24 |
I wanna be Dave Join Date: Jun 2004 Location: San Jose
any new pics
06-24-2005, 09:07 PM | #25 | |
Quarry Creeper Join Date: Jan 2005 Location: New Orleans
06-26-2005, 03:40 PM | #26 |
I haven't had much time to work on the flat bed really. And the past week I was pretty busy working on my other trucks. Rebuilt a few and fixed others up for a event our club had this weekend. I hope to get some progress done on this truck in a few weeks. |
06-29-2005, 01:53 AM | #27 |
Newbie Join Date: Jun 2005 Location: Kailua Kona
i want some body off pics please |
06-29-2005, 04:54 AM | #28 |
Here are a couple off body shots. I still need to add to the cage a bit,and I need to work on a front bumper brace. |
06-29-2005, 03:23 PM | #29 |
thanks. i was thinking of making a project just like that ecept with a full cab. jus dont have the money yet |
07-10-2005, 04:10 PM | #30 |
Finally another update. I spent a few hours yesterday and today working on the front bumper. I also finally brazed the front cage supports onto some brackets to bolt onto the frame. I started with a length of 1/2" steel sqaure tubing and cut it down to the width I wanted. I wanted to have the tips bend in to flow with the grill of the body. So I marked the two spots where the ends would be bent in. Then I clamped the piece in my vice. Using my jigsaw with a metal blade I made one insert on each mark, almost cutting all the way though the tubing. I bent in both ends and lined it up with the body. And it looked perfect, I was worried I would need to do a second cut on both ends. I brazed the cuts to hold the new shape. Then I followed up with bending up a mounting bracket to fit over the frame rails. I drilled a set of holes in both the back of the bumper and through the bracket. The bumper is tapped to 6-32. The upper bar took several attempts to get the right bend and look. And I am very happy with the end result. I still need to make the bed for the truck, and a roof over the cab. Then several other details to follow. I also plan to add some more pieces to the cage for added detail before it gets painted. |
07-10-2005, 04:22 PM | #31 |
Quarry Creeper Join Date: Jan 2005 Location: Crafty mexicans and your glass candy...
lookin good now you got a spot for a functioning winch...
07-12-2005, 11:39 PM | #32 |
i cant wait to start my buildup ow that i am back from vacation!! are you gonna run a winch
