05-13-2005, 11:09 AM | #1 |
Rock Crawler Join Date: Nov 2004 Location: in a basement in Kalispell, MT
| ? shimming tlt ring and pinion
Junked a ring and pinion last night. Wondering if anyone has had longer gear life by shimming them. Also trying to find some 5x7mm shims with no luck. thanks |
05-13-2005, 11:27 AM | #2 |
Rock Crawler Join Date: Jan 2005 Location: Bethlehem, GA
Hmmm, haven't had the first trouble with my axles yet. Have lost a spure gear but that was because i was running 48pitch as opposed to 32 pitch spur and pinion. Now haven't had the trouble. I would be curious how many people have trashed a TLT axle.
05-13-2005, 04:35 PM | #3 |
Newbie Join Date: Apr 2005 Location: Akron
i shimmed mine from the start. when i first put them together they seemed kinda gridy. i think i just used traxxas 6mm shims, i believe they also make 5mm but i had the others. i put one on each side of the diff and one on the inside of the pinion. now nice and smooooooth. have not noticed any problems with a 1mm bigger shim just in case. just have to play around to see where you need to shim. just remember you need alittle lash.
05-13-2005, 06:22 PM | #4 |
Rock Crawler Join Date: Jun 2004 Location: SW, Connecticut
I shimmed mine almost exactly like TXLT did after I stripped a ring and pinion. Its been working a lot better now.
05-13-2005, 07:17 PM | #5 |
Gold Star Baby Momma! Join Date: Feb 2004 Location: Maumelle, Ar
| any questions? that was after running crappy bearings out of a fox so not really tamiya's fault Kevin |
