01-06-2008, 03:12 AM | #21 | |
Quarry Creeper Join Date: Nov 2007 Location: NJ,USA
the pics in your link are not there anymore:-( | |
01-06-2008, 06:47 PM | #22 |
RCC Addict Join Date: Nov 2005 Location: Saving for Nationals!!
01-07-2008, 09:45 AM | #23 |
RCC Addict Join Date: Mar 2005 Location: MESA, AZ.
[quote= The RC4WD tranny steering kit is...well...not so good. You'll do better mounting your servo behind the tranny where you can get a straight throw at the disconnect actuator rod. PaloAltok5 & Tanis are right on about the straight throw of your actuator rod. This is how I mounted my servo on my SW3. You can see I mounted my servo almost in the center of my chassis. Mounting the servo to one side will give you problems on side hill crawls. You can see in the pictures that I used plastic spacers to adjust the height of the servo. I also used a clevis not a collar on the disconnect side of the actuator rod. You will need to drill a small hole in the disconnect shaft. With the clevis you can mount your servo lower and still have a straight throw. You should be able to set your truck on a flat surface on each side RTR, and not have it tip over. This setup works great, every time without fail. |
01-07-2008, 05:28 PM | #24 |
thanks I got the R2d today,i'm going to the hs tomorrow to buy a servo to set this up. |
01-09-2008, 06:25 PM | #25 |
I mount the R2d and is working good, i connect the servo to other rc to check the disconnect system and is working good. the motor i got it for free so thats what im using for now. is a 65 turn integy motor |
01-09-2008, 06:48 PM | #26 |
Quarry Creeper Join Date: Dec 2006 Location: Corbin KY
great loooking rig. I am also planning on putting a R2D in my SW3. Is your servo set so at neutral it is in 4wd? Also, do you have any top veiw pics of you mount? Thanks
01-09-2008, 07:31 PM | #27 |
01-11-2008, 07:18 PM | #28 |
Rock Crawler Join Date: Sep 2004 Location: South Orange County
looking good
01-17-2008, 07:35 PM | #29 |
what did you use to mount your link to the disconnect pin?
01-19-2008, 03:20 AM | #30 |
got the wheels.Mayhem Engineering Beadlocks |
01-19-2008, 03:25 AM | #31 |
01-20-2008, 09:01 AM | #32 |
| more pics |
01-20-2008, 09:07 AM | #33 |
Rock Crawler Join Date: Mar 2007 Location: perkasie, pa
looks good man, gotta lose those body mounts!!!!
01-20-2008, 09:10 AM | #34 |
01-20-2008, 09:30 AM | #35 |
Tire&Foam Extraordinaire Join Date: Jun 2007 Location: C.I. Compound, Tyler, Texas
I would suggest you straighten the throw of the linkage on the R2D. The way it's set up with the linkage arm angled will cause some binding. The straighter the throw the better. Consider mounting the arm on top of the aluminum servo horn. That would eliminate the angle you have now. R2D's can be difficult to disengage when then are bound up.
01-20-2008, 10:24 AM | #36 | |
01-22-2008, 04:09 PM | #37 |
its coming along whats left before she is running? |
01-22-2008, 04:56 PM | #38 |
01-22-2008, 09:05 PM | #39 |
Newbie Join Date: Jan 2008 Location: Wilmington
What type of wheel wideners are those??
01-22-2008, 09:47 PM | #40 |
I wanna be Dave Join Date: Sep 2005 Location: Dirty South
I might have missed it but what servo are you using on the R2D ?
