12-31-2007, 03:46 PM | #1 |
Quarry Creeper Join Date: Nov 2007 Location: NJ,USA
| MY Build-SW3
This is my first build, i will update when i get more parts. THANKS to "iwantoffroad" he is helpping me with this build CHASSIS SW3 AXLES TLT RCP copper alloy gears and locker full bearings MIP cvd's Fat Rock alum. C's RC4WD front steering links RCP high clearence alum. knuckles Alum. servo mounts High clearance/Heavy Duty 60/40 derlin links RCP Crawlers Aluminum Upper link Mounts Last edited by iwanttocrawl; 12-31-2007 at 03:50 PM. |
12-31-2007, 04:33 PM | #2 |
RCC Addict Join Date: Nov 2005 Location: Kansas
looks lika a sweet build! should be a good one to watch!
12-31-2007, 04:47 PM | #3 |
Rock Crawler Join Date: Oct 2006 Location: Tacoma
looks like you need to shorten up those upper links a little. other than that it looks good |
12-31-2007, 06:04 PM | #4 |
Rock Crawler Join Date: Sep 2004 Location: South Orange County
looks good good job what else is have you bought did you decide on tires motor and electronics yet? |
12-31-2007, 06:07 PM | #5 |
Pebble Pounder Join Date: Mar 2007 Location: Perkasie PA & Port Norris NJ.
Looking good! I just did an Sw3 for my son and it is one sweet chassis! I also did the bent delrin links and it gave it big time clearance..
01-01-2008, 08:31 AM | #6 |
01-01-2008, 04:37 PM | #7 |
Upper links look fine, they will rotate rear pinion up for better driveshaft clearance and rotate the front just right so you can wiggle the front end over. Looks like a good start. Motor: try the Integy V10 handwound either 50t or 55t. |
01-01-2008, 06:58 PM | #8 |
Rock Crawler Join Date: Jun 2007 Location: Flint/Mt. Morris
Cool truck. Did you make those links? I think theres an online store I want to associate links with besides Extreme. I think Bender has refered them but it is totally lost right now. I may need some links for my sw3 too and I think Hc delrins would be cool. Did you get the r2 with disconnect?
01-01-2008, 07:24 PM | #9 | |
yes I order the R2 with disconnect and the R2 RC4WD Tranny Steering Kit. | |
01-02-2008, 04:46 PM | #10 |
So you just told them your wheelbase, chassis and axles and they did?
01-02-2008, 04:51 PM | #11 | |
go here: http://xtreme-rc-hobbies.net/store/i...cPath=58_59_61 | |
01-03-2008, 01:05 PM | #12 |
I got the shocks (traxxas Big Bore) and mount them: |
01-03-2008, 05:13 PM | #13 |
Quarry Creeper Join Date: Dec 2006 Location: Corbin KY
great looking rig.
01-03-2008, 07:08 PM | #14 |
one of your shocks has a spring not on properly how are your drag links all ready scratched up whene are the wheels and tires and motor and esc coming in |
01-03-2008, 07:51 PM | #15 |
01-05-2008, 04:14 PM | #16 |
New pics,I had the back links on the wrong way. |
01-05-2008, 11:37 PM | #17 |
Newbie Join Date: Jan 2008 Location: Waynesville, OH
cant wait to hear how this performs, im thinking of picking up this chassis if i see good performance(not judging benders quality)
01-05-2008, 11:50 PM | #18 |
01-06-2008, 12:11 AM | #19 |
RCC Addict Join Date: Nov 2005 Location: Saving for Nationals!!
Just a quick thought, and Tanis chime in here if you want. The RC4WD tranny steering kit is...well...not so good. You'll do better mounting your servo behind the tranny where you can get a straight throw at the disconnect actuator rod. The kit puts it at a pretty nasty angle that will cause it to bind up, or to even bend the rod depending on the servo you use. http://www.rccrawler.com/forum/showt...SW3#post954779 And I agree with Tanis, use the V10 50t or 55t and a 15t pinion seems to work best with it, but you'll need to "massage" the opening to get it to fit through the hole! |
01-06-2008, 12:20 AM | #20 |
I agree with PaloaltoK5, if you can get your linkage for the disco as level as possible, it will engage/disengage better, as it is pushing/pulling straight, instead of on an angle. What I do for getting a bigger pinion on, is put it in the other side of the tranny and stick the end with the setscrew out the motor side, then put it on the motor. It usually takes a couple of tries to get the pinion exactly where you want it on the shaft though. Massaging the opening would be easier(why didn't I think of that), good tip man |
