05-22-2005, 02:28 AM | #1 |
RCC Addict Join Date: Apr 2005 Location: Seattle
| VMG Motor dead?
Anyone ever have a sudden death of the stock motor? It ran fine yesterday. I took the suspension apart to install a 4-link and stretch. At the same time, I soldered a Z connector to my 7.2 volt rx pack, so I plugged it all in to test it. The steering works, throttle does not. I tried the stock battery configuration, same thing. I plugged the battery pack directly to the motor, nothing. My ESC can handle the voltage, no problem. I am running an Airtronics ES-01 that is rated to 7.2, so I don't think that's the problem. Any ideas? |
05-22-2005, 04:28 PM | #2 |
Rock Stacker Join Date: Jan 2005 Location: Upland
Did the motor make any noise when you connnected it directaly to the battery?
05-22-2005, 07:02 PM | #3 |
No, no indication of power at all. I tried it with a rx pack and with the stock battery setup.
05-23-2005, 01:25 AM | #4 |
Seems like it fixed itself. Today, the motor is working. Weird...
05-23-2005, 11:48 PM | #5 |
Quarry Creeper Join Date: May 2005 Location: Auburn
its haunted. it might have been a hung up com brush?? id check the brushes, I dont know exactly how the motor looks on one of those things. But if its a open can id peek at that stuff. maybe give it some lube or com drops to clean her out |
